These work fantastic had mine 6 months now .Make sure you use an MPPT split control unit, 1ah to starter the rest to hab batteries.
without the technical jargon who knows?Next question please. I am fitting 2 x 115 watt panels, without all the technical jargon, is it best to put them in series or parallel?
So the controller will let you cable up either way (that would not be the case with many) and both ways will provide the same harvesting within measureable limits.2 x 115w Monocrystalline panels supplied as a kit with upgraded Victron Smart Solar MPPT from Onboard Energy.
This one
If you have 2 panels, series with an MPPT controller is the way to go. The controller will drop the voltage to the 12v for your batteries, and up the current available. Even in the rain, I get between 2 and 5 amps charge, but up to 18 amps on a really sunny day running 2 x 120watt panels.I've got all the bits now just wondering which was the best way of coupling. I have already got a 12 volt panel on the engine battery.
