Split charging
Vanterrier
Could anyone interpret the wiring diagram below and tell me if both batteries get charged when hooked up to mains or if the split charger relay only charges both from the alternator?
There's a switch on the control panel with two options... habitation battery charge or Van battery charge, suggesting its one or the other on mains.
I don't yet have a solar panel.
It's a 2008 Autosleeper Symbol on a Peugeot Boxer van.
Thanks
K ;)
A power diode can be installed "pointing" to the vehicle battery and will keep it charged if the charger is connected to the leisure battery. A slightly lower voltage will reach the vehicle battery but not enough to worry (less than 0,6v dropped)
If you have a 2008 Autosleeper, I would imagine you have a Sargent System installed? This would be reinforced by the colours shown in the diagram e.g. Orange/White is the -ve connection.
Be useful to quote the number on the cover of the big silver box that has the fuses and breakers in it. Maybe an EC155 if a smaller PVC, or maybe an EC325 or EC328 if a larger Motorhome? I suspect you have an EC155 as they are quoting 8 fuses in total.
Now based on my assumptions above the answer to your question "tell me if both batteries get charged when hooked up to mains or if the split charger relay only charges both from the alternator? There's a switch on the control panel with two options... habitation battery charge or Van battery charge, suggesting its one or the other on mains." is that whichever battery you select on the control panel is the battery being used - BOTH for charging when plugged into Mains AND providing habitation power when off-grid.
It is a EITHER/OR selection and not a BOTH.
It has a Bonus plug in services PDU 4M, not a Sargent :(
Is there a way to charge both batteries without having to switch over manually.
I remember fitting a voltage sensing relay to my IH some years ago, but I was following instructions then and cannot remember how to now.
How would I "point" a power diode? What connections, where and would additional fuses be required?
Please be aware that I am an engineer so can follow simple but clear instructions but electrickery is a dark art to me ;)
K ;)
K ;)
The diode would be connected to the 87 (Anode) and 30 (Cathode) terminal of the split relay directing the voltage to the vehicle battery. The current of the diode should be about 3 times that of the charger's max charging current. A switch can be included to disconnect when the leisure battery system is disconnected. No need if that's a maintenance charger.
What you haven't actually said (unless I missed it) is what you are actually trying to do or achieve?
You have asked for some info and then there is a discussion forming about adding diodes, etc. to add some functionality.
I would like the charger to charge the leisure battery until "full" then switch over to the van battery if it is not already fully charged and back again when the leisure battery needs charging. So sensing both batteries and charging whichever needs charging. All without me switching back and forth manually.
I was originally hoping someone could tell from the circuit diagram if that was what was happening already.
Hope that clarifies what I would like.
K ;)
K ;)
There are several battery maintainers that you can purchase and fit from the likes of Ablemail, vanbits, Sterling etc.
I posted this DIY device a while back that works extremely well at actually keeping the starter battery fully charged and properly maintained so as to prolong the batteries life and not just keep it able to start the van.
If you're not quite sure about anything then just ask.
I have a garage automatic gate mechanism that I built almost 20 years ago. It runs on a small auto 12v battery that is permanently connected to a 13.5v 2A constant current power supply that keeps the battery charged. The motor draws a peak 30A when the gate is operated which is supplied by the battery and then the supply tops up again. On the second battery now after the first died at 12 years of age.
If you supply the vehicle battery with 12.5 V @ a max of 2A, the battery will always start the vehicle without issues. When you drive away, the alternator will do the rest.
K ;)
Thanks
K ;)
That is not a wiring diagram. It is a marketing schematic. Not to be relied in for anything at all.
Spend between £7 and £10 on a multimeter. Measure the voltages of the batteries when on and off charge, with the switch in the various positions. That way you know what by our van is doing.
