If you have registered the problem within your warranty period then it shouldn't matter if your warranty runs out before it gets fixed. It's when the problem was registered with the warranty provider that's the important date, not the repair date.
Engine would have been scrap.I wouldn`t be too sure about that
They completely forgot they`d dropped the oil, taken the filter and filler cap off a Marea i put into them for service many years back.
Whenever i pick a vehicle up from a dealer i always have a good look round and lift the bonnet to check fluids etc.etc.
That`s when i immediately saw the filler cap was missing, further checks revealed oil filter, dipstick ad sump plug missing![]()
They`d also completed a 5 mile test drive ( in that condition ) if you believe the paperwork as well![]()
I wish we could use an old timer mechanic, we have a great one here in Dunoon. Unfortunately the van is still under warranty and Fiat insist that it is a Fiat Professional garage sort it , otherwise it invalidates the warranty.
A spoonful of brake fluid does the same thing,wd as you say not good but for testing works to give a clue,not a fix.I have an old Hymer with a 2.5 turbo diesel which had the same problem resulting in the water pump being replaced. Problem sorted.
I would strongly advise against using WD40 which is in fact only a cleaner. When I was in the motor trade a common cure for a squeaky water pump was to use suds oil which lubricated the pump from the inside. For the uninitiated suds oil is a water soluble oil used as a coolant and lubricant when turning metal on a lathe. This is however only a temporary fix.
It is worth looking for a mechanic who specialises just in replacing water pumps as many garages find it cheaper to buy in expertise using someone who replaces pumps all the time. It is quicker and cheaper in the long run. Good luck.
Is there a mechanic out there that may be able to identify what is making the squealing noise coming from our van when we start up and it continues for a short period of time. If you stop and start again the squealing noise will start again. The van is still under warranty. The van has been in a Fiat Professional garage three times now to no avail. It has had the timing belt tightened and a new alternator fitted - none of which stopped the squealing. The garage even recorded the noise and sent the recording to Fiat but Fiat couldn't help.
The Fiat is our sole vehicle and professional Fiat garages are a fair distance away, which causes a great deal of inconvenience and expense so any thoughts would be much appreciated. We only have six months of warranty left. Some of you may have heard us leaving The Green Frog!
Get a role of flame retardant material . Roll it into a tube shape and use tie wraps to keep it in shape. Place it along the front [ the pulley side] of the engine from above resting on the engine mount. It will provide a cover above the belt and pulley system.Mine does this occasionally too. It’s only a couple of times a year and stops after maybe 5 seconds. I’ve had the dealer look at it twice and everything is tensioned correctly, the alternator seems fine and there are no fault codes. The conclusion which I think a couple of people have mentioned is that it’s probably water getting onto a belt. For sure there is sometimes water in the scuttle and it seems to depend on wind, volume of rain because it’s not always there.
I would much prefer a solid diagnosis but I’ve decided not worry about it. We’re out of warranty now, but if problem does arise attributable to this, it’s at least logged and maybe Fiat will be kind.![]()
A drop of cooking oil will do ok just to find fault,silly to wast money on stuff just for that me thinks.DO NOT use WD40 or any similar products, get yourself a spray can of "BELT DRESSING", toolstation. amazon etc, many places sell it just do a search on google, it is readily available, try spraying on only one of the drive belts at a time and if it stops squeal, then this will be the problem area. Belt dressing should not be considered a permanent fix, although it can cure these squeals for ages. It may perhaps let you isolate the problem.
