runnach
Problems I see David if altering by extending or dropping the horizontal box section is, starting with the latter, leaving MH prone to possible damage if MH did bottom out. The former, adding overall length, bottoming out issue again, plus extra cost (which may not matter to you) on ferry costs, if you use them.I can understand why people are commenting about the ball bit maybe being the problem. I initially thought this as well.
So thinking the taller bit of the ball area was stopping the door hinging, is it serving any purpose anyway?
I would think the only reason this is present is if you need the ball fitted higher? and if not that whole section could be cut away (I am happy enough cutting away metal. It is welding it back I have the problem with!)
IMG_20230401_094519_791 by David, on Flickr
And this photo shows that the door does indeed foul on that
IMG_20230401_094243_149 by David, on Flickr
But .... even it that were gone, the door still fouls on the entire bar itself
IMG_20230401_094315_861 by David, on Flickr
It is a close thing. If the bar was maybe 3" or even maybe 2" further out there would be just enough clearance. Or if it were slightly lower, or a combination of the two? If this towbar was made for this particualt model of Motorhome, I bet it would be that bit longer and/or lower.
Now I personally am not in a position to cut and reweld ( and many thanks, Runnach for your offer to have a look), but I wonder if I could actually redo the mounting holes so it is actually fitted further outward to the rear?
This is the plate that goes to the chassis and bolts onto it with three bolts each side
IMG_20230401_101012_748 by David, on Flickr
The plate goes against a cross-member at the end - does that provide any strength when bar is loaded which would be lost if moved back and away from it?
If I made three new holes for the bolts, I would be closer to the end with one of them, but actually closer to the centre with the two others, so strength not compromised I am summerising? Or extend this plate with a piece at the end so it can be fitted further away but still remains butted up at the 'inboard' end?
I would be very interested in the opinion of those who know about metal structures and strength and the impact of changing things to see if just drilling three holes in different places would cause any problems? (just a note about towbar usage ... used 99% of the time as a "deterrent bumper", and when ball used, it is either for a load carrier hanging off it, or a small 'garden' trailer with max weight 600kg but usually way less than than)
This post was initially just to express some annoyance, but maybe there is a fairly neat solution?
While I appreciate your comment with the current setup being a faff, maybe easier to just live with the faff. A conundrum though with a rear storage locker.
