NorthernLoop
Hello,
I took my camper in for the 2nd service and I asked them to check the discs & pads before the MOT. Van has aftermarket alloys which I fitted 2 years ago and I have done 16,000 ish miles on them.
24 hours after the dealer had the wheels off I was driving home, and noticed something odd with the rear. I thought I was on the rumble strips of the road. This went away as I was then driving through 30mph zone. After leaving the 30mph I enter National Speed limit, started to increase speed when I then looked at my rear nearside wheel which was then pointing 45 degrees away from the van!
I managed to stop before the wheel was fully disconnected.
Behind the wheel hub cap of the Alloys, 4 of the bolts were fully loose and the locking wheel nut was snapped and still in the hub.
The dealer has now started to drag their feet and said the wheels were torqued correctly (180mn) which is what I think I torqued them to when I installed them
Note the centre of the hub has snapped and this was stuck inside the alloy.
Damage to the van is wheel hub/alloy and wheel arch (luton camper)
Other than the dealer either over-torquing or under, what could have caused this?
