I guess the logical place would be by the fridges own thermostat so you can monitor the fridges behaviour?I got a discount down to £11.89 so not too bad
The thermal inertia is quite high and when moving from freezer to fridge it took c30 minutes to come up - I should have left it outside in 25⁰ air for a few minutes if i was that bothered - another downside of being a cheap skate!
Anyway the bottom line is that my fridge-freezer is working fine with an initial cool rate to match the rejuvenated Thetford.
I got down to -18⁰ in freezer but this gave -3⁰ in fridge so my usual running position of about a third of the way round the dial is still a good setting.
It got me thinking as to where the thermostat is placed and I came to conclusion that it would probably be in the fridge any thoughts anyone?
If I could change one thing on the Govee units it would be to have the temp probe on a lead so you can position it just where you want (and maybe have the unit itself outside?)
Something which I have seen on a few youtube videos is a fridge fan to distribute and even out the air to eliminate cold/warmer zones - I am not referring to fans that you fit at the rear which is a common 'hack', but fans INSIDE the fridge itself.
This is a pretty fancy kit in this first video, but you can get little battery powered ones as well (like in the second video)
