Cdmoreear
Spotted this the other day. Thought it pretty interesting. Probably not a retrofit product but worth a look. Thetford revolutionises RV toilet and waste water infrastructure
The toilet uses grey water to flush. This in turn saves fresh water. The w/c has an integral macerator allowing small diameter discharge pipe. As there are no solids the discharge pipe can be positioned over any foul water drain to empty the tank.ok so a bit confused, is the video showing the emptying of the black water down a drain? Also the cynic in me sees you being limited to buying thetford dosing modules.
You ordered one Baz?It had to come an app that tells when the toilet is full .
No way I'm an appnaphobeYou ordered one Baz?![]()
Does this mean that I cannot leave my grey water tap to dribble, as I won’t have any grey to flush
