Hi all. After reading on here Peugeot boxer has a chain belt. I verified with the garage that does my Peugeot boxer 2.2hdi engine 2015. That they had said at my last service that the timing belt was due a change beginning 2021. They said yes it was due to a change. I said no it's chain. They opened the bonnet and said. That bit by the fan belt if it's plastic it's belt. If metal it's chain. Mines plastic = belt. They then pointed out afew other things that indicated belt. Checking handbook= belt. So where I thought that I was alright mine was chain. I have found out different. So if you have a Peugeot boxer check with handbook / mechanic visual. Not what we read. Also found out that 2011 Land Rover freelander has the same engine as my Peugeot boxer and that is belt. ,,I get 30 to the gallon boxer. 22 to freelander,,,,,,,,,,,,,,,,,, yet to find out. If it is a ford engine or. ,,,,,reason I have put this on the forum is that I have learnt so much from the forum. And this was the First t.time I was getting. Or reading/ understanding wrong. Thanks for all help advice on all else. Love reading. Following your threads brian
