Molly 3
Do you have to add on the price for lithiam charger's ?
Yes as you post.
Hymer MLI 580 available as basic 3500, but with every extra they did on it and I put on it comes out a 3720 empty and plated at 4200kg If I do not get the medical later I will either have to lose all the extras or sell it. I added the weights of the extras and they came out to a lot of the extra weights.
Yes you would have to check everything to do with charging the batteries Caz, alternator, cable from alternator/starter battery to leisure batteries, mains chargers and all cabling between them and the leisure batteries and all fuses in those circuits.Do you have to add on the price for lithiam charger's ?
Actually Del the cable you have fitted would be fine for lithiumThink I spent enough this first year of ownership. 100w solar, gas bottle, rear view camera ( thanks Tezza ), upgradeed battery’s ( thanks Nabs) and now the ctek. Hoping to enjoy it more in 2019. I want to get it as good as I can while I still have an income. Trouble is, I like to tinker. Get the Spain trip out of the way, and use that to see if I need more solar.
In the process of fitting a ctek, almost finished, so lithium not an option.
I fitted the solar from a kit I got from Complus Energy. I can recommend them. It came with a mppt controller. All fitted as per .
The Ctek has a mppt fitting for the solar so the other one might be surplus to requirements.
Gob smacked to get, what might be a “well done “ from one cranky olde codger. Split charger either u/s or not fitted.
Post lottery win, I could be in the market for a “ Managon”.
We have an Accordo 125 as in the picture and had one of these https://www.towbars-uk.co.uk/produc...erter-type-approved-2012-fixed-flange-towbar/ fitted last year. A trusted mechanic friend fitted it for about £120 if I remember correctly. Insurance company wanted it professionally fitted and it saved me the effort.Ditto a towbar is my next must have, would be interested to know how much yours costs as I'm being quoted stupid prices.
I don't understand.............. But if you don't have one of these magical devices, then it might be worth your while fitting one. If you don't know what they do, here is a very basic explanation, they aren't expensive, they fit in the main VB to LB cable which should also have a high capacity fuse in place immediately before the SCR.
The Split Charge Relay senses when your VB has become fully charged then immediately switches the power supply to you VB's. When the engine is stopped and charge is coming down from the solar panel, the SCR again senses when your LB(s) are fully charged and then switches the excess current to the VB keeping that tip top fully charged as well.
Sorry I didn’t understand either.
I am so very sorry Trotter but I have absolutely no idea what you are going on about! After all to me anything normally to do with electrics is some kind of black art from the dark side!!
I think that some of the confusion might be the use of the CTEK letters, as I have a top of the range CTEK battery charger that does nothing else than charge and recondition batteries when plugged into a 240v socket.
This might explain better about what a split charge relay actually does: -
https://www.simplysplitcharge.co.uk/help/
Most people I know who have converted/built their own vans have one of them fitted
