Washer pump fuse???
taylo482001
Hi all, I have 2013 Fiat Ducato 2.3 Multijet with no screenwasher operational (the blades are working). I have looked for the fuse and can only find the F09 fuse this is named as the headlight washer pump sited under the bonnet, F43 is named as windscreen wiper (+key) sited dashboard RH side. Am I correct in assuming the F09 fuse is the one to check? Thanks in anticipation of a quick response as I have probably answered my own question LOL.
I would first connect 12v direct to the pump to rule out the switch, wiring and fuse.
Thanks, I did that through some wires and cigar lighter this blew the fuse immediately so I direct wired it to stand alone battery this almost melted the wires. this seems to that there is not a fuse for the pump on the Ducato?? Anyhow I bought a new pump from Amazon £13.00 fitted this and all and all is well.
Thanks all for the previous advise.
I had a similar problem with my Fiesta there was current but not working. I pulled the pump out and it was a gel in the intake to the pump, I blew it out in reverse and the blob blew out with the air stream , Put the pump back and checked the tank for more gel, I did not know what it was but but it was a light blue and probably a gel of the additives and not the alcohol.
