Phantom
Our moho taps have switches that operate the watertank pump. I just did the washing up and all was well, but when I operated the tap again the pump suddenly stopped after 2 seconds. The bathroom taps don't trigger the pump now either so it's not the tap switch. The water tank is about full and the hab elecs have not tripped as everything else is working. I checked the "Pumpe" fuse on the Electroblock and it is good. I'd be surprised if the pump would abruptly fail in just 2 seconds but that's all I can think of. It's too dark now so will try to find the problem tomorrow. I'm thinking of putting 12v direct to the waterpump to test it. Any other ideas?
