I will go with Tezza save me writing it all outIf you carried every spare part that you might need you would be seriously over weight, if your water pump packs up all you will lose is not getting water to the taps or toilet, both can be overcome with a bottle of water until you get a new pump
Another question would be which water pump? Habitation water, engine coolant water or windscreen washer?On another motorhome forum which I read occasionally someone told a newbie that they should always carry a spare water pump. Not something I've heard before. What is everybodys opinion? Am I remiss or is he winding up an innocent?
I have heard that on the Dethleffs forum that they are only getting two years out of the pumps and carry a spare. Have even seen someone asking what model so they can carry the same pump. My thought was why fit the same pump if they fail after two years? I purchased a Reich twin submersible pump with non return valve which gives 19l per minute from leisure shop direct which was the cheapest supplier that I found.On another motorhome forum which I read occasionally someone told a newbie that they should always carry a spare water pump. Not something I've heard before. What is everybodys opinion? Am I remiss or is he winding up an innocent?
Hab water pump - makes sense.Another question would be which water pump? Habitation water, engine coolant water or windscreen washer?
I've been meaning to do that since mine leaked a month or so after fitting (it was fitted badly. garage came out and swapped it over. At their cost after a bit of pushback from me)I carry a spare fuel filter unit as I’ve know several instances of the UFI plastic unit failing.
I suppose those who had a failure for something are worried the same fault will reoccur or will happen to others? I replaced my pump earlier this year and it was in my mind to keep the old one in the van as a precaution (the old one is 90% ok so could be used if needs must). Right now it is in the shed and I'll keep it, but probably not carry it around (Tezza33s logic).On another motorhome forum which I read occasionally someone told a newbie that they should always carry a spare water pump. Not something I've heard before. What is everybodys opinion? Am I remiss or is he winding up an innocent?
I'm sure GMJ always carries a spare Water Pump, so not a wind up!On another motorhome forum which I read occasionally someone told a newbie that they shom/home to refill Wateruld always carry a spare water pump. Not something I've heard before. What is everybodys opinion? Am I remiss or is he winding up an innocent?
My coolant water pump was on the point of failing and found when we did a timing belt kit - mahoosive job to do.Hab water pump - makes sense.
Windscreen Washer pump - have to be pretty paranoid to carry that
Engine Water Pump - ned to have a big tool kit and a lot of knowledge plus a touch of paranoia to bother carrying one of those AND be able to fit it
I think the general consensus is not to carry the spare naked filter, but a complete unit of filter prefitted in housing? save the hassles of trying to get it right. Not got round to buying a replacement, but seeing as the current one will have had under 1,000 miles under its belt it should not be a critical thing!Have a read here, same filter 130 and 160 engines
Fiat Ducato 160 multi jet
Fired up the m/h this .morning and let tick over for a wee while then noticed what i thought at first was water dripping, turned out to be diesel coming from the filter housing. Not had a chance to remove or to be honest its too freekin cold. Anyone else had this happen before ?wildcamping.co.uk
If I want to top up without moving the moho, I get out the watering can. Strikes me that a submersible pump as well might be a bit OTT.I'm sure GMJ always carries a spare Water Pump, so not a wind up!
I also have a Reich 19l submersible Water Pump that I use to drop into a 25 ltr Water Tank Top Up Jerry Can. I wired an on/off switch and attached 4m of cable with a Heike [?] socket that plugs into the TV socket. Saves moving the M/home when water top up needed!
In my own case, the garage fitted the filter in the existing housing but for some reason omitted to fit the new O-ring that was supplied (and might also have cross-threaded the cap as well, which would not help matters). This is certainly an item I would probably never have replaced as part of a service any more but do it myself (The VW T4 fuel filter was brilliant - just dropped into a hole into the inner wing, two minutes to swap over and cost under £2.50 from Halfords for the same brand VW fitted).
I understand the Clutch failed on my Motorhome when it was in Spain - replaced at a cost into 4 figures whilst out there (before my ownership).
I keep a bare filter at home for use when I need to change it over. The removal tool must be held in a vice, the filter placed into the tool and the lid of the filter removed with the other part of the tool. Reassembly is the above reversed, ensuring that the correct torque is applied. It simply cannot be done away from a vice, tool and torque wrench or the casing can split.I think the general consensus is not to carry the spare naked filter, but a complete unit of filter prefitted in housing? save the hassles of trying to get it right. Not got round to buying a replacement, but seeing as the current one will have had under 1,000 miles under its belt it should not be a critical thing!
Friends had a Bürstner and also carried a spare submersible pump due to frequent failures. I've has no issues to date (touch wood) with a Shurflo. Had a Jabsco pump installed on a yacht a few decades ago. When that failed after 12/13 years, we were fortunate that the old galley footpump had been left in place and were able to use that to pressurise the system until we were able to purchase and fit a replacement electric pump.I have heard that on the Dethleffs forum that they are only getting two years out of the pumps and carry a spare. Have even seen someone asking what model so they can carry the same pump. My thought was why fit the same pump if they fail after two years? I purchased a Reich twin submersible pump with non return valve which gives 19l per minute from leisure shop direct which was the cheapest supplier that I found.
