Exwindsurfer
8 degrees overcast but bright ish
And across the water too, although there is the prospect of the sun peaking out from behind a swathe of angry black cloud. 9 degrees at present, but temperatures falling steadily to 4 degrees, so the cloud must be preparing to depart!Wet here
I was very sorry to read that and hope you're discharged quickly.Lovely day and 10 degrees but I’ve only seen the inside of a hospital with a broken arm after a tumble! 🌤🌤🌤
It looks like the weather is going in the right way, hopefully when we arrive it'll be back to normal3° at 8am.
Sunny, but Northerlies will keep temperatures down to 13.
An improvement !
You'll brighten our day , when you get here.It looks like the weather is going in the right way, hopefully when we arrive it'll be back to normal![]()
We've got the same van, it could be interesting when we get there then. I'm sure we can sort something out.You'll brighten our day , when you get here.
Have you the same van, or larger..?
That parking space could be crowded, they use it for the ongoing road repair machines.
Don’t forget to give the keyboard a thorough clean before Susie uses it Bill! Hope your arm mends as quickly as it can and that it doesn’t get too itchy under any plaster.Only down to 7 degrees at 1 in the morning in Blackpool and expecting another fine sunny day to come.
(Not a bad effort with my nose)![]()
I hope Bill does not use PC's within public libraries.Don’t forget to give the keyboard a thorough clean before Susie uses it Bill! Hope your arm mends as quickly as it can and that it doesn’t get too itchy under any plaster.
Tony
