At 66 I would have been up for it. Now I've turned 78 I've just been 'persuaded' by the family to leave things like that to a garage.Looked at it,looked at the adblue emulator waiting to be fitted, thought not much of a job,looked at the new cambelt kit and water pump waiting to be fitted,thought at 66 Im too old to be rolling around the drive doing that in the middle of winter maybe next month.
5yr old van 30k progress?
I'm soon going to be 75 and wish I could leave everything to a garage. Some things I accept I can't do. BUT today, considering that we are taking Hardly to Norway in the Summer, I want to renew the entire (most of it) braking system when it gets warm so I priced everything up. New discs, pads, calipers, brake shoes and drums, wheel cylinders and rubber hoses, and master cylinder. Cost from the usual GSF and Euro is about £753 for the parts.At 66 I would have been up for it. Now I've turned 78 I've just been 'persuaded' by the family to leave things like that to a garage.![]()
Spend the money as you cannot take it with you, ask can you help out in the garage, good way to keep an eye on job.I'm soon going to be 75 and wish I could leave everything to a garage. Some things I accept I can't do. BUT today, considering that we are taking Hardly to Norway in the Summer, I want to renew the entire (most of it) braking system when it gets warm so I priced everything up. New discs, pads, calipers, brake shoes and drums, wheel cylinders and rubber hoses, and master cylinder. Cost from the usual GSF and Euro is about £753 for the parts.
NOW: the question is, can I do the job?
My friendly 'No VAT here, matey" garage chap would I suppose do it in a day. He charges £60 / hour. This is less than 'er indoors's hairdresser who doesn't have to rent a garage, buy compressors, car lifts, welding gear and five thousand pounds of miscellaneous tools, and a £4,500 CAN Bus diagnostic computer. These hairdressers really annoy me, what they charge for poncing around with a pair of £10 scissors and some shampoo charging £60 an hour. This isn't some posh lah-dee-dah hair coiffeur either, just a small shop in a row of news/conf/tob/betting/chip shops in a small town in the middle of the country.
Anyway so my garage chappie would charge £480 for an 8 hour day's work, and I reckon it wouldn't take him that long. I'll ask him for a quote. Hardly did pass the MOT perfectly OK but he is 25 years old and has done 68,000 miles. So I think it might be prudent to spend £1100 to make sure he doesn't go in the ditch. That's a lot cheaper than changing a wet belt . . . . . . or fixing a mis-diagnosed fault on a modern tin box.
I agree with you regarding master and slave cyls, better just to replace - I've rebuilt a lot of calipers in the past though as the kits can come with new pistons if required, however most I've rebuilt the pistons have cleaned up and after a set of seals they have been fine.I've long since given up stripping calipers/wheel cylinders ....
If they are leaking ....it's usually because one or other of the seals is damaged usually from corrosion in the cylinder wall caused by moisture in the brake fluid ...
Years of swapping one cylinder only to have another or the master cylinder go shortly after .
The last landrover I did ....
I swapped all cylinders and replaced all the brake lines .
BUT deff worth replacing the brake fluid ever few years ...
Ohh and I only ever use decent known branded brake parts ....cheap bits are cheap for a reon .
Good luckTook van in for its MOT + swap tyre round and ajust handbrake .
Best bit about the MOT Graham is I don't pay for it lolGood luck![]()
It can only get better mateDrove from Zaragoza to Benicarlo hoping to speak to Tambo about the replacement of the over bed reading lights, after the final foul up by Camper UK at Lincoln; they had external Valeters clean the M/home after the floor delamination repair, and the Valeters must have used a power washer on the roof ...
First overnight stop en route to the ferry, we had a damp duvet, and no reading lights because water ingress had blown the LED lamps ...
I had expected to have just a quick word with Tambo and to return for the fitting of new lamps, but he was in a right strop dealing with a German M/homer; initially he said to call back around 5pm, then said he was too busy, and that I should come back tomorrow, EARLY ...
I had just driven 150+ miles from Zaragoza, so my arrival was not exactly tardy! Were it not for the fact that I need his technical expertise, I would have told him that I would go elsewhere.
He may have been busy, but politeness costs nothing. I'll visit tomorrow after a night on the Benicarlo Aire and see if Tambo is in a better mood!
He worked from his house garage and Van prior to COVID, and was very helpful and innovative with his repairs, fixing problems that other Technicians had said could not be repaired, and he built a thriving business.
Since COVID, Tambo has moved into a purpose built Workshop, with an expanded Accessory Shop, but has lost the personal touch on which he based his business. He was a bit 'off' last year when I needed a new tap fitted - again I would have been quite happy to let him have a quick look to see what was required, and then return for a fitting appointment, but he no longer gives one a chance to explain the problem.Very sad lowering of customer service
Nylock nut not down enuff, thread to short, no breakfast for you today naughty boy.Fitted a couple o buzzard to tidy up the connection on battery posts. Cheers Jeff for the help in rectifying a problem that arose. View attachment 75125View attachment 75126![]()
The reason the nyloc was used is because I dropped the dome nut which is now down a hole hiding. As soon as the nylon touched the screwed rod it then screwed the rod further into the rivnut on the baseplate.Nylock nut not down enuff, thread to short, no breakfast for you today naughty boy.![]()
