rayc
Yes but why are they only used on SEVEL motorhomes.? You would expect the dynamics of Ford or Mercedes to be the same?The sidewalls were stronger so they wouldn't deform so easily causing the flat spots.
No, I don't think you would get a better ride. I know you'd get a better ride.I have always had CP types as they were fitted originally. Do you think I would get a better ride with non CP. I have to say my Fiat Rapido has never been what I would describe as smooth.
I should have said: the 112/110 load rating means 112 if there is one wheel each side. If there are twin wheels (common on the rear of larger motorhomes) you use the lower figure (1060Kg) when calculating the load on each wheel.Then look at your tyres: they will be marked with a load rating (something like 110 or 112 or even 112/110) and a maximum pressure.
I believe the design of the CP tyre by Michelin was paid for by the Fiat/Citroen/Peugeot SEVEL company. That is why CP tyres are fitted as standard to their motorhomes. I know that when Citroen was bankrupt in 1934 that its biggest creditor was Michelin. Michelin took over Citroen becoming its largest shareholder. To this day Citroen fit Michelin tyres to their vehicles. In 1968, Michelin were looking to sell their interest in Citroën - and an agreement was struck with Fiat to transfer the remaining 49% from Clermont Ferrand to Turin. Far from me to say its the money but obviously by limiting choice of tyre over the life of a vehicle there is money to be made.Rayc. Memory also suggests that CP was invented by Michelin. Perhaps it was the French influence within the Sevel collaboration that did it.
If i were in the market for new tyres for a sevel camper i would be seriously considering the new Michelin Cross Climates which now come in commercial sizes and load ratings
They are supposed to be good on slippery wet grass and mud !
But as these are all season then all corners should be changed out so your not mixing summer and all season
My Merc 5 ton sprinter drives beautifully on its Michelin Agilis Alpin winter tyres
50 + years in the trade its what I,ve always recommended and done unless asked to do other wise which wasn't very oftenIf you choose to put new tyres on front thats fine by me but hopefully your not recommending others to do same
Not for front wheel drive in MHOthis is what i said but apparently i am wrong
Yes, good point. I picked 112 as a likely value, but perhaps a less likely one would have been less misleading. 110 is 1060Kg.Good post. Just one thing. By quoting the 112 load rating as 1120 kgs you might give the impression that the load is 10 x the rating. This isn't the case. Anyone using the load rating should check the load rating table to find the correct loading. For example a load rating of 100 is equivalent to 800kgs not a 1000kgs
Good to see the details in this listing, whilst it is a commercial tyre and not a camper tyre it has the snow flake symbol, that mean it is made of a different type of rubber than a standard tyre, it's not so ridged in lower winter temperatures, so gives a better footprint, (dependant on tyre tread design), I have at the moment a selection of tyres on my car and MH, just the way it worked out. On MH I have Bridgestone Duravis, (originally had narrow tread economy commercials), on the front and Michelin Camper on the Rear.You might also consider a brand not often mentioned on this site, but these Pirelli’s get really good ratings on wet performance, economy and noise ........
Worth mentioning if you have different tyres on different axles,what kind of tyre is your spare?In France the breakdown services or garages won't fit a tyre if it doesn't match the other on the axle, as it is illegal there.You could end up having to buy two. I would change the tyre myself, but many don't. For that reason all five of my tyres match.No need to worry if you don't cross the briny.
