Vanterrier
I had the same but my fault was in the BCMThanks all
Got meter onto connections at motor and there is a supply ok and linkage can be turned a bit manually ( not seized) so it has to be a seized or burnt out motor....
i’ve got a fiat ducato 1998 19TD my wipers stopped working, thought it was the motor stripped it down it was the mechanism had seized up, i would spray all that with WD40, if you can get the motor off just check that on it own too, if you can get to the nut that connects the mechanism to the motor maybe just undo that then try your motor in situ, hope this helps
The exact same thing happened to us at Crianlarich in torrential rain as we were heading to Arran! He checked all fuses etc and is a fab hand at fixing things. Not this time though. We chanced it to Arran and by luck, we had our very own micro climate. It was glorious. (We’d phoned around some garages first and couldn’t get any help for a few days anyway). Once back from Arran we headed back to Crianlarich where we were booked in via Green Flag. Pouring again. Husband had his nose to the windscreen
if you need to replace your wiper motor, well regarding any parts i’ve found Autodoc really good, i replaced both back lights / both headlights too very reasonably priced , they supply older vehicles too as mine is 23 years old ducato 19 TD,
