St3v3;n206 said:I could see it, but now cannot. Odd. Teething problems no doubt
Test1;n226 said:Has the photo gone?
Edina;n73 said:Using a down pipe fitting like this means you don't have to hold a funnel in one hand and pour with the other.
Measure the diameter of the filler and get a fitting slightly larger so you can file/sand down for a tight fit.
Fletch6;n433 said:I use a watering can with a bit of hose on it. I would imagine it goes in a lot faster than using a 90° fitting. Then again if you're filling with bottled water there's probably no difference lol
