Exwindsurfer
At least it’s not a flashing blue light behind you.Hi guys I View attachment 71607 have a thetford electric flush toilet and the red light on the display is flashing all the time not just when it’s full any ideas ?
Thank you very much RogerAccording to the Manual, the holding tank (cassette) may not be positioned correctly.
Page 11. Troubleshooting section.
Cheers Gordon I'll have a look today .Are you in a red light area ? Jeff make sure the cassette is as rog says but also make sure if you have the pull out handle type it's locked into situ
I've checked the cassette is in the right place and all that but the barsteward is still flashing lolololIf the cassette is not secured, the red light may flash a false alarm of an unexpected movement [but not in the bagging area ...]
Don’t ask!!Just wondering if there is anything inside the cassette that has to do with this light ?.
Rog even with the cassette out the red light is still flashing ?When you get home Jeff, try using Tank Cleaner, it could just be something as simple as a dirty contact.
GENUINE Fenwicks Pipe,Tank and Interior Cleaner 1 litre | eBay
Fenwick’s Waste Pipe & Tank Cleaner is the only cleaner you will need to clean your pipes & waste tank. Only need 1:5 ratio with warm water to clean down surfaces inside the interior.www.ebay.co.uk
Don’t forget to keep releasing the internal pressure while it’s doing its stuff, otherwise you’ll blow a seal.
