Very cool. Have you got a picture of your roof?
phil you have lost a fair bit of waight. but find it hard to believe you will be flying that drone. mind post the video and put a helmet on best of luck. just looked at the date. so it must be trueNew (old GoPro Karma) drone arrived at home Yesterday. So I will be flying again soon.
Phil, are you running your fridge from your leisure batteries?
Not yet, but the fridge and maybe the water heater in the future.Phil, are you running your fridge from your leisure batteries?
It's definately worth doing that and making the most of the energy that would otherwise go to waste.Rae's water heater now automatically takes the wasted energy from his solar panels when his batteries are full!
Having both is good, but if it were the case of one OR other, the 300W element would be preferable over 240V for anyone who wants to wildcamp (A normal Mains element of around 2kW is a big hit on the batteries whilst on - better to spread out the same load over time)I got a 12v 300w immersion element last year but not fitted yet, am leaning towards keeping the 240v in but wiring it in as it was never completed by previous owner. Ideally I should take the tank out and get another stub fitted so I can have both. That way I could heat water by solar when harvesting or generator in winter. Currently water is heated when engine runs or kettle![]()
Are you going this route because you don't have the LPG Truma water heater?I got a 12v 300w immersion element last year but not fitted yet, am leaning towards keeping the 240v in but wiring it in as it was never completed by previous owner. Ideally I should take the tank out and get another stub fitted so I can have both. That way I could heat water by solar when harvesting or generator in winter. Currently water is heated when engine runs or kettle![]()
The built in element is 1KW but still a big hitHaving both is good, but if it were the case of one OR other, the 300W element would be preferable over 240V for anyone who wants to wildcamp (A normal Mains element of around 2kW is a big hit on the batteries whilst on - better to spread out the same load over time)
