That's as good as it gets without a B2B charger.Here is charging from a 2017 Fiat Ducato alternator. This was a drive down a motorway, a bit stop - start and slow progress due to an accident. I will be fitting a B2B charger
That's simply not true in my experience.A standard alternator regulator will not drop back to 13.7v, voltage will remain above 14, depending on the load and revs.
I have not seen that with a conventional alternator system, that's working correctly, that's in my 25 years of being an Auto Electrician. I used to change a lot of alternator regulators that from new charged at 13.8v. But if yours shows it and your system is ok perhaps they now manufacture with that facility, I don't think it would be of an advantage, as many special systems would do the opposite and charge at slightly high voltage, 14.5volts for 30-45 mins, then drop back to say 14.3volts, like boat systems.That's simply not true in my experience.
I have two meters visible when driving. One shows the starter battery voltage. After a few minutes running it's up to 14+ and after about 45 to 90 minutes it drops back to around 13.7v.
The state of the hab batteries doesn't affect that: they're connected via a B2B charger. And it's not a smart alternator: just a fairly hefty standard one.
post you are replying toThis alternator is about five or six years old. If it was doing what you describe, I'd be worried about its design.
I had expected it to simply put out about 14v regardless (it's rated at 215A, significantly more than it is called on to supply). It was a pleasant surprise to find that it has multi-stage charging built in.
The one it replaced never really managed to be on top of its job, but it was only a 90A one. Allow 15A for the fridge, 40A for the b2b, 10A for lights, 5A for other electric loads, that leaves very little left over for a decent rate of starter battery charging.
I was replying to your comment that an alternator ought to drop back to 14.3v after 15 minutes at 14.5v. That's a fault, in my opinion.post you are replying to
Not sure what post you are replying to but it would seems that you probably have a none conventional alternator fitted, as you say was a 90A original and now 215A.
Does the ECU have a role to play in voltage control?I was replying to your comment that an alternator ought to drop back to 14.3v after 15 minutes at 14.5v. That's a fault, in my opinion.
The person who I bought it off didn't seem to think that my alternator had any special "smarts" in it.
The price suggested it was a very basic one. Perhaps I just got a bargain.
Not in my 1999 vehicle, no.Does the ECU have a role to play in voltage control?
I think you did! Has he got any more? (I think I need a new alternator anyway).I was replying to your comment that an alternator ought to drop back to 14.3v after 15 minutes at 14.5v. That's a fault, in my opinion.
It was a few years ago, but I expect they're still in business. I'll need to look the details up, though.I think you did! Has he got any more? (I think I need a new alternator anyway).
I am not going to respond to this post anymore as it would appear that you have not read or understood the points that I made, and you are miss quoting what I have said, there is no point in going round & round.I was replying to your comment that an alternator ought to drop back to 14.3v after 15 minutes at 14.5v. That's a fault, in my opinion.
I did not misquote you at all.I am not going to respond to this post anymore as it would appear that you have not read or understood the points that I made, and you are miss quoting what I have said, there is no point in going round & round.
You are correct that a battery cannot be charged TO 14v, but it can be charged AT 14v. Then it needs time for the charge to sink in.A 12 v battery con not be charged to 14 volts .check after a cooling of period about 6 hours 12.7 is fully charged .
This is their website. http://www.londonessexautoelectrics.co.uk/ They also have an ebay shop. https://www.ebay.co.uk/str/london-essex-autoelectricsI think you did! Has he got any more? (I think I need a new alternator anyway).
i dont think your aloud to run with gas on. please correct me if i am wrong .p.s. dont light my firer. ok pjDitto, well I actually leave it on gas whilst driving
You are allowed but ONLY if you have a crash protected regulator (e.g. SecuMotion) and burst protection on the gas cylinder. You need both, one protects the low pressure supply from the regulator and the other the high pressure hose from cylinder to to regulator. Without these the bottle must be turned off when travelling.i dont think your aloud to run with gas on. please correct me if i am wrong .p.s. dont light my firer. ok pj
