The thing is the heater may see a voltage that low, but the Battery itself maybe nowhere near that low level if the device was not installed right.As you say any battery that gets down that low has used a few life cycles!
The peak current is 6.5 amps on a Truma, and that isn't a sudden peak: the fan gently ramps up. A battery that drops to, say, 11v under that sort of load needs charging or replacing.The thing is the heater may see a voltage that low, but the Battery itself maybe nowhere near that low level if the device was not installed right.
For example, at shows, I used to get lots of people asking about why their 12V Compressor Fridge wouldn't turn on properly and had the "low voltage" light on. Reason is lots of people - including professional convertors - wire up the fridges using wire suitable for the running current of the fridge (under 3A) but ignore (or more likely just don't know) that the fridges may pull 50A or more on the in-rush when the compressor kicks in.
Instant massive voltage drop with thin wire resulting in a voltage well over 12V at the battery end, but under 10A at the fridge end.
Heaters not so dramatic but if wiring is substandard, a battery at 60% SOC may not be enough to start the heater.
I'm pleased to say that my fridge does at least have a 10mm feed - which it does need because the run must be getting on for 8m from the relay above the engine!Happens on Fridges; Happens on Diesel Heaters, especially the chinese ones with incorrect voltage readings to start with. Who knows what wiring may have been used to wire a Truma heater? You could say nobody would wire a Fridge with 1.5mm wire - but they do.
When I said AGM not suitable I should have been a bit more specific.Oh, having a B2B will make a big difference. When you have a battery that you can only discharge to 50%, starting at 100% is very different to starting at 85%.
I think that AGM is very suitable for leisure use. In fact my batteries (which are proper deep cycle batteries, not leisure) are AGM.
I agree about Varta being a good buy.
No, I said 1mm, not 1.5mm.You could say nobody would wire a Fridge with 1.5mm wire - but they do.
And I said Fridge, not heater.No, I said 1mm, not 1.5mm.
I seriously doubt any professional would use that.
Not many Truma heaters are installed by DIYers at all, let alone ones stupid enough to use 1mm cable - even assuming they could buy any.
This discussion is about heaters.And I said Fridge, not heater.
Stop trying to constantly pick holes in discussions.
In my experience, the problem is as likely to be a half-melted fuse somewhere in the line. Shouldn't be, but all too often is!I will check the wiring to the heater in my van - I'm not optimistic because when I put the original build extractor fan over the hob on high speed it dims the built in down lighters noticeably.
I opened it up and he wiring is desperately light and the van loom is the same.
The over sofa spotlights are similarly skimpy supplied but at least these can be replaced with Leds at one third the rating - same goes for most of the other lights!
As you said earlier despite the otherwise good build quality of my 2004 Bessacarr the wiring and electrics are 'down to a price' for their whole range.
Look at the title -This discussion is about heaters.
The thtead started about fridges, but this discussion was specifically about power to a Truma heater.
And I expanded it to power to fridges to get it back on topicThe thtead started about fridges, but this discussion was specifically about power to a Truma heater.
I would say that is not a thin-wall insulation wire and is probably 1mm2 and possibly, just possibly 1.5mm2.OK - what was anyone's money on with regard to the supply wiring to my Truma?
No prizes for guessing that it's not 2.5mm²
It measures 1.5mm diameter/thickness so even if 'no wall' insulation area is c1.7mm².
Apparently if thin wall this is 0.5mm² flex.
So I have a Truma heater installed by Bessacarr that doesn't meet the manufacturer's specifications!
In fact because of the distance from hab battery to heater it should be 4mm².
Maybe because the first 5m are 6mm² they think the next 2 can be 0.5 and the average is >2.5??
I'm disappointed but not surprised
Did someone say no supplier would install one with such thin wire?!
