Oppy, UFO. With such a busy social calendar, how am I expected to keep up. They knew who I meant. Besides, since I edited it, I’ve no idea what you mean.Oppy has a coachbuilt van Del, are you sure you have the right members name?
Its a 2009 Adria Twin / Fiat Ducato panel van conversion - all metalIs it f/glass or alloy
I used Hammerite Silver Smooth direct to rust on both my 2004 and my current 2010 vans. I rubbed down the primer to get a good key after removing as much flaking paint as possible. Its alarming how much paint lifts when you do this from what initially looks like a small area. I painted over the edges and did two coats and am happy to report it worked although i had to watch out for new areas popping up. Mine was restricted to the roof and gutters on both vans (so far).Hammerite smooth has been suggested. There are two types -
- Direct to Galvanised Metal
- Direct to Rust Metal
Products | Hammerite
Browse through our great range of paints product here. Discover the Hammerite products and add your perfect shade of paint for your home.www.hammerite.co.uk
If all the flaking paint will come off then I will be painting on the shiny primer, which seems to be adhering to the metal.
If only some of the paint will come off then I will be painting on a mix of shiny primer and paint.
Given how common this problem is has anyone direct experience of applying Hammerite to a van roof? Which Hammerite did you use?
This one been on for 4 yrs now https://www.screwfix.com/p/hammerite-smooth-metal-paint-white-750ml/69444Hammerite smooth has been suggested. Which Hammerite did you use?
Thanks, that's what I was looking for, someone who actually used a paint, Hammerite Direct to Rust Metal, and it worked. If it been OK for 4 years that sounds good to me.This one been on for 4 yrs now https://www.screwfix.com/p/hammerite-smooth-metal-paint-white-750ml/69444
They stopped making proper red led 50 years back, the stuff you buy now is dirt, epoxy 2 pack zink rich is best and self healing if it gets a scratch, this should be overcoated with 2 pack poly or acrylic, today's car paints are water base except the top coat which is a two pack.I used hammerite on the bare chassis when I first started building a car. From memory, three coats of red lead, and then 8 coats of black hammerite. It's only been about 14 years, but it seems to be holding up well.
The fireplace is at a low level..No ladder needed (unless Trev is a Leprechaun ?)You've posted those photos before Trev. I didn't quite understand why you didn't use a ladder.![]()
