nabsim
Still his base DelTreat it as a wonderful weekend away in the Peak District.
I would have recommended Charlie if you weren’t happy fitting your own. Unless he’s moved on, the CS he’s on is just a fiver a night.
You do much the same thing every time you change a gas bottle.Have a chat with you next week if that’s ok. But nervous about doing it ourselves![]()
Think I owe him a visit. Maybe a phone call? Busy, busy till October. The Peaks are bootiful in the autumn.Still his base Del
How is a vet going to help with fitting their gas system.The James Herriott museum is worth a visit. Just up the road.
Not just a vet: a dead vet. But not a fictional one, it turns out. It's actually located in the real vet's surgeryHow is a vet going to help with fitting their gas system.![]()
Yes - I suspect that most insurance requires professional fitting or testing of gas equipment.I have never had an insurance company ask for anything like that. Have other people had to produce such documents?
Sorry, you have not actually answered my question in that long reply.Yes - I suspect that most insurance requires professional fitting or testing of gas equipment.
You don't require annual checking for private use so original system (however old) is covered.
Technically anything before the regulator is operator serviceable so a Gasit-Gaslow install can be done DIY and not need testing.
When I did mine I also put in a BBQ point which was after regulator or course. So I arranged for a GasSafe inspection of whole system which cost about £80 if I remember correctly - much cheaper than paying for installation.
You can hope so, but depending on the supplier, it may be a forlorn hope.As the system is "Pre-Regulator", it is in the eyes of Gas-safe no different than changing out your existing Calor bottles. However being a responsible installation engineer, it's important to perform all checks post installation. If your fitter has provided an invoice of supply and fit then you have that reassurance that it has been done correctly (or at least you hope so).
We always leak-test all installations of Gaslow and fill them with Gas as part of the installation, so that everything is up and running when you leave us.
Are your people gas safe registered Nick?As the system is "Pre-Regulator", it is in the eyes of Gas-safe no different than changing out your existing Calor bottles. However being a responsible installation engineer, it's important to perform all checks post installation. If your fitter has provided an invoice of supply and fit then you have that reassurance that it has been done correctly (or at least you hope so).
Sorry you thought my answer was too long and not exhaustive enough.Sorry, you have not actually answered my question in that long reply.
You say you got a certificate and you said you 'suspect'. I am asking you if your insurer specifically asked for documentation.
No, I said it was long. You decided to deem it "too long"Sorry you thought my answer was too long
It didn't answer my question in any way, so there we agree.and not exhaustive enough.
Which condition, exactly? What "it" could they require, according the the policy?I can confirm that it was a condition of my insurance - so they could have requested it at any time and you can bet your life they'd want to see it if I made a gas related claim especially if the noticed I had changed from initial build.
You seem to be confusing the meaning of "professionally" if that is what it does say.My insurance said either professionally installed OR serviced. So initial build covered 'forever' and any addition either done professionally or GasSafe checked.
Once certified ok 'forever' as no regular service required on personal use van.
QuiteAs Nick confirmed gas storage is not specifically part of regs
but I think that if you move to under slung tanks from bottles then some sort of certificate makes sense.
Again my GasSafe man checked my installation over including 'hoses' so I'm confident that I have sufficient documentation if required.
There we are in agreement.I cant speak about every single insurance policy (hence my initial use of 'suspect') but I'd thoroughly recommend that everyone should read what you have and check that you haven't given the insurers a get out.
Gosh, lighten up H! People on here kindly share their personal stories or what they've seen/heard... they don't expect to have to pass a strict exam afterwards!No, I said it was long. You decided to deem it "too long"
Not what I wrote, not what I thought, not what I implied. Which leads me to doubt your ability to glean the exact meaning of an insurance policy requirement.
Gas Safe is meaningless: there is a specific qualification needed for LPG installations on motorhomes and touring caravans. Almost impossible to find people with it. Without it, they are no more qualified than the postman.
Professionally has two possible meanings: one is "paid for" and the other is "done to a good standard". That's why a well-written insurance policy should be more specific. "Serviced" is not the same as "regularly serviced".
What is the actual wording of your policy that leads you to this view?
Quite
Is he qualified to check this installation? If not, the documentation isn't worth the paper it's written on. Not saying it isn't worth getting checked: just that the document is worthless.
I simply doubt that your are correct in saying that it needs to have any sort of certificate, I don't think that a certificate issued by a generic Gas Safe person has any value at all, and I don't think that fitting a refillable gas cylinder is in any way different to fitting a replaceable one. That's a user task.
When it comes to underslung tanks (which was NOT the subject of the discussion) it is rather more of a grey area. Their weakness is how well they are fitted and how easily they can be damaged by external events. The gas bit is the easy bit.
This started off as a simple request. As far as I know, it still is.Anyone know of one they can recommend down here in the South, please? Last van we got fitted out at one of the Warners Shows, as they are day shows currently not sure there will be fitters there.
