SquirrellCook
Halfords are only capable of testing a batteries starting performance.
With our local Halfords, even that's debatable!!Halfords are only capable of testing a batteries starting performance.
This is not my understanding of the situation. I can't see any possible way that leaving the panels connected could damage the controller. What is the basis for your assertion?you must disconnect the panels before disconnecting the batteries, not doing so could damage the controller.
Alternatively cover up the solar panel but if you do make sure the wind doesn't blow them off.
It is true to say that some mppt controllers need to be connected to the battery before getting solar input, so that they can tell whether they are connected to 12v or 24v batteries, but disconnecting wouldn't matter.
Even then, I routinely switch one of mine between battery banks in full sun and have never had a problem (except that the clock usually loses about 20 minutes).
Despite being connected to two panels in series, it always seems to settle for 12v output. I've never swapped it between 12v and 24v batteries, though. Perhaps I should try that some time...
In a word, "No"If you don’t disconnect power from the panels you have a live supply don’t you, could spark and may blow controller fuse when reconnecting. I fitted fuses between panels and controller to make it easier for maintenance
If the installation is using a Victron SmartSolar controller, than it is very easy to go into Victron Connect and just turn off the Charger component if you are doing work to the system on the battery side. That is the method I use to disable the panels (typically when doing some evaluation/testing and don't want any solar input).If you don’t disconnect power from the panels you have a live supply don’t you, could spark and may blow controller fuse when reconnecting. I fitted fuses between panels and controller to make it easier for maintenance
Non MPPT 10A solar regulator lost battery connection over at least a week and a section of regulator had burnt out.guess it couldn't cope with open circuit solar power.take care!!!
Yes. It is absolutely fine to disconnect the batteries when the sun is shining on the solar panels.Hi all. No. 35 says in a word no. Does that mean it is ok to leave the leads just lying there whilst batts are removed. And solar still connected.
