Steveandjulie
Fit two so if one goes down the other will hold you over.
I've only just realized the weight of a large capacity battery 60 kg wow Julie doesn't weight that much. will definitely get 2 smaller onesI tend to go for multiples - easier to handle (weight wise) and partially habit (rarely can fit one biggy in the vans I do) but it doesn't really matter in terms of performance.
Unfortunately out of our price rangeOne LiFePO4 battery
Leisure Battery - Cheap Leisure Batteries - Express Next Day Delivery - Alpha Batteries
Order your next Leisure Battery online from Alpha Batteries today! We stock a wide range of Leisure Batteries ready for Express UK Next Day Delivery.www.alpha-batteries.co.uk
That battery isn't available at that price, though.![]()
12V 100AH POWEROAD BASE LITHIUM LIFEPO4 BATTERY - Alpha Batteries
Poweroad - Time to go Lithiumwww.alpha-batteries.co.uk
£499.99 for a 100Ah LiFePO4 battery, how much do you think 2 AGM batteries with the same useable capacity would cost?
And also may be worth considering the life of an AGM.......
Good decision. I have some AGM deep cycle batteries that weigh 75KG each. They're really quite hard to move. The good news is that I've not had to move them for several years.I've only just realized the weight of a large capacity battery 60 kg wow Julie doesn't weight that much. will definitely get 2 smaller ones
It will be available at that price, I expect, depending on what happens to exchange rates.
But it isn't available at all right now. Wildebus suggested a couple of months, I think. The website doesn't say.
Lead time wise, that is the expectation from Alpha as told to me by the guy who runs the place.It will be available at that price, I expect, depending on what happens to exchange rates.
following on from a few comments later in the thread, when do you NEED to upgrade? is it an urgent need or can you hold on for a few months to get what is a well priced Lithium Battery and likely a worthwhile change?We are going to upgrade our single 110 amp lead acid battery to two 110 AGM batteries.but have noticed you can get larger capacity batteries so was wondering which is best two 110 batteries or a single 220 any advice greatly appreciated
