Mr and Mrs Tupcox
Same same but different!Not the same ...
I don't use EHU very often and like the idea but I have a Victron inverter/charger so when it is on EHU the inverter charges the batteries at 120 amps So it wouldn't work for me
I have a switch and 200amp relay to connect all batts together just in case the starter bat is low, also spreads the load/charge from solar even though i have a 1amp charge from voltronic
Thats sounds a good way to go ..I have a switch and 200amp relay to connect all batts together just in case the starter bat is low, also spreads the load/charge from solar even though i have a 1amp charge from voltronic
For us we use the hover every day as we have dog .which take about 10mins .
i have a 110w on my m-home. charging 2 batt= leisure. plus the engin battery. ok summer. not out in winter. ok that is me. but ok in winter.Thank you for the reply alwaysared, I liked the idea of having 300w to quickly charge the two leisure batteries, then once full, charged the inverter battery, as we only use the inverter infrequently,
But as you say, I can’t find a Victron MPPT controller that does dual batteries,
Victron do make a dual battery controller, but not MPPT.
As you state, I think the Bluetooth function is a good idea.
