jeffmossy
Rally Organiser
As it would be a major job pipping a central heating radiator into our utility room I started to look at other various options first a electric blower and that was costing a fortune in electricity , then tried a electric oil filled radiator and that turned out not to be efficient , so I decided to go for a freestanding diesel heater
This would fit down the side of the washer perfect
Next was to drill through the outside wall for the exhaust outlet , be careful , as you can see the vibration of the large drill bit caused a lot of the pointing to fall out of the brickwork . Another job for next summer
The battery and charger sat at the rear of the unit perfect
Next was to drill a hole through the back wall into the lean to brick shed for the fuel line into a 20ltr fuel tank
All to do now is test it
Not only does it heat the utility room but the kitchen is attached to this room and it also heats this room up as well , both rooms warm as toast , what a great result
