I have an Air Assist kit to fit on my Motorhome and and am not sure where to fit the gauge set.
It is a kit with a compressor so I don't need to worry about running an air hose to the valves each time I want to add air, so it is just a matter of seeing the dials and enough access to push the valves to release pressure.
I can't see a neat place on the dash to install without looking a bit out of place, and thinking while it would be hard to fine-tune if not within reach of the driver, once you have the pressures set up, how often do you really need to alter them?
For those with Air Assist, where did you fit your gauges, and how has it worked out for you?
