Thanks for that have checked all fuses are ok any more ideas pleaseHi can anybody help off on hols on Friday so testing the lights and no side lights on offside HELP!!! Please.
Thanks have checked all fuses all ok anymore ideas were desperateThe nearside and offside lights each have a fuse of their own, so I would start there.
Yes checked with multimeterHave you checked fuse 12 and 13 with a continuous meter ? Sometimes they can look fine but are actually blown
thanks Jeff there the fuses I've been checking but just noticed the side light in the headlamp is working so think it's a break in the wiring going to the back .I have been having a quick look for you Lee and found this diagram , if it helps . Jeff
Fiat Ducato (2002-2006) Fuse Box Diagram
Main fusebox under the dashboard on driver’s side for LH drive versions, on passenger’s side for RH drive versions Fuses Specifications No. A Description 12 5 Front right-hand side light - Rear right-hand side light 13 5 Front left-hand side light - Rear left-hand side light 24 5 Control lights -knigaproavto.ru
Hi Lee, is this the side marker lights? If so the fuse for mine was under the bench seat next to the leisure batteries their are a bank of fuses there. Mine is a Fiat ducato and a Burstner build.Hi can anybody help off on hols on Friday so testing the lights and no side lights on offside HELP!!! Please.
Yes I have the bulb and for rust but the is 4 lights out on that side so I think must be a break in the wireI assume you have checked the bulb and it’s connections. A tiny bit of rust or corrosion on the contacts could stop it working Check the earth wire connections to the body too
Also, by law any lights you have fitted, have to work, day or night, whether you need to use them or not.
Yes I no what you mean but traveling to Scotland in the dark.Of course but who is going to stop you and check in daylight, newer vans of course have daylight lights too, but not an 03 van.
Obviously, they need to be working but if I was off on my jollies it'd the last thing I would worry about, fridge and water heater are first after the engine g/box n brakes.
Thanks no it's all side lights on the off side except the one in headlight. It's a auto trail chieftainHi Lee, is this the side marker lights? If so the fuse for mine was under the bench seat next to the leisure batteries their are a bank of fuses there. Mine is a Fiat ducato and a Burstner build.
And you Jeff love to lorraineHave a good holiday![]()
