Geek
There almost certainly isn't one. Each tap has a switch to turn the pump on. Systems that have a pressure switch to control the pump usually have a switch. Ones with tap switches don't need one: they don't have the unreliability of the pressure switch and the danger of small leaks emptying the water tank into the lockers.I still haven’t located any switch to turn the pump on and off. Not sure that there is one
