Okay, can give me experience on this one over the last four and a half years all year round in the U.K.
My compressor fridge is a Waeco 110ltr with freezer compartment inside at the top. Manufacturer says it averages 48Ah per 24 hours, think that ties in well with the new 50litre models using 24Ah over a 24 hour period. Lot less power needed for smaller fridge if it will serve your needs.
I have 2 x 100Ah Lifepo4 battery’s, 2 x 150W solar panels flat on the roof each going to its own mppt controller plus 100W folding panel I can put out when solar not as good. 1 x 30amp B2B which obviously helps when moving but useless static. 2 x 30 amp smart chargers for if I need to use the generator.
Weather isn’t constant but best guess is for seven months of the year in the U.K. I have no problems. As I can stay parked up for a couple of weeks or so at a time for the other five months I run the generator every couple of days to get the battery SoC back to 80%. I killed 3x90Ah Bosch PowerFrame battery’s in 12 months simply because I couldn’t keep them charged up which is why I bought the genny.
My fridge is on 24/7 for most of the year, it’s usually only off when I want to defrost it for a day. I did try about 6 weeks without it over last winter after all my mates saying you don’t need one in cold weather. I freeze a lot of chicken for the dogs and can keep my veg fresh easily two weeks in the fridge, I found it a pain throwing stuff out as it was well past it’s best even shopping every few days so won’t be turning it off again.
Performance in the heatwaves this year. My fridge control goes from 0 to 10, it is a little under 2 and has been all summer, everything stayed well frozen and anything I took out the fridge nice and chilly. I don’t have temperature gauges to say what’s what but it definitely works better than the fridge in the house. Saying that I don’t have milk in drinks and don’t drink beer so my fridge is probably opened less than a lot of other folks
If/when my fridge packs up I will more than likely go for a domestic 230V replacement as so much cheaper than any kind of van fridges and I already have the infrastructure
