Exwindsurfer
Sorry i dont i just looked on amazon and found it as it was the right diameter and its about 350 mm long.Do you have the link or details? I looked on Amazon and the closest I could find was way too short.
I am sure it is ScotiaIs your tail pipe definitely 65mm od, I'll see if I can expand the 63.4 to fit.
It is just the tip about 400mm long.I've just been in the van but forgot to look under and picture it, but do you need just the tip part or the longer part that goes to the silencer, a picture of your might help too.
The closest there was a Transit tail pipe but it was only 55mm. I need 65mm. Thanks anyway.If you look on ebay at the seller 'everyexhaustpart' there's various parts that may be what you want.
I got an end for my ducato exhaust from here.
Just searched on Scotia and I get lots of laminates and beading.I am sure it is Scotia
I'm sure I have 63.4 od stainless tube at the back of the rack would that fit inside your exhaust pipe?
You could take advantage of the generous offer from Scotia and buy one of these from eBay to fit itThe existing pipe would have to be modified to be able to clamp onto an internal pipe which would be difficult. I would rather not start cutting slots in the main exhaust system. Thanks anyway. It seems strange that this exhaust tip is unavailable as a standard item. There must be thousands of motorhomes with it.
