Mobilvetta
Hi I've noticed that the 120 watt flexible solar panel I have on the roof of the motorhome appeared to be water stained. I've been up there today and removed what appears to be a celophane wrapper that covered the top of the panel, don't know if this should have been removed when it was originally fitted or not in 2018, but water had got in between the celophane and the solar panel causing the stain, I've now cleaned it off though with a quick wipe, the panel itself doesn't seem to have been compromised.
There is a bit of residue on the panel now with removing the celophane, a bit like when you remove a wrap from a body panel, not sure what would be best stuff to use to remove it so the solar panel is nice and clean.
I have a multimeter, is there a test I can do by the Epever PWM controller to see if the panel is performing, not sure with the cloudy weather up North if it would be producing any power. I have disconnected the leisure battery's for now.
I have managed to get it booked in with Leisure Tech in Clitheroe, but the earliest they could get it in is just before Xmas, I've asked them if they could fit at least another Panel and a Victron MPPT controller instead of the PWM while it is there, so that it is future proof if I want to go down the lithium battery route at a later date instead of the two 110amp Gel batteries I currently have.
I also asked if they could fit a victron B2B, but they said they wouldn't have time until after Xmas, it appears that all motorhome and caravan technicians are mowed out with work. I've attached a couple of pictures of before and after. Thanks for readingvDavid
