HurricaneSmith
It's going to be a beautifully mild day, with temperatures around 11 degrees. There's the slight possibility of an odd shower by late afternoon.
5 degrees here, but forecast is for a heady 8 degrees throughout the day from 11am [which suggests the degrees will be knocking off for Xmas around noon, and the scoreboard won't be updated ...]Bright and sunny but still only 7 degrees.
The only comatose people are those with hairy feet ...Mild, misty start.
Light southerly breezes, opening the clouds. Shafts of sunlight playing through.
Cathedral bells calling the faithful to prayer.
As their biggest celebration was Last night, there'll be a few hangovers amongst them.
20 max..
13 overnight, ( not a problem, we'll be comatose, by then.)
PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPiiiiiiiiiiiiiiii........................go away!!Bright, calm 20 degrees in the sun this will drop to 11, after sunset.
Forecast not great for tomorrow, Tony. Be careful, which I am sure you will do.Still sunny in Kirkcudbright but a cold wind. Bit worried about those posts from you guys further north mentioning snow as we’re starting to head for home tomorrow.
