RoaminRog
Perfect! Nothing to worry about thereJust bin up to our Van switched on ign, all lights illuminated then Glow Plug light went out after 1 sec before I started engine is that correct, thanks Chris.
It was showing 1 degrees on dash at the time.Sounds ok it may stay on longer depending on outside temp .in the summer it may not even illuminate ,the beauty of high pressure diesel injection
Thanks for the reply something to not worry about for the mo then. Chris.Perfect! Nothing to worry about there![]()
You only need to be concerned IF the glow plug light stays on after you’ve started the engine, but be aware, the glow plug warning light is sometimes used to indicate many other electrical problems as well.Thanks for the reply something to not worry about for the mo then. Chris.
I stand to be corrected but I think ALL Diesel engines have a glow plugs.
My 2002 Fiat 2.8JTD does not have glow plugs, 2.3ltr engines have them but 2.8JTD engines are fitted with a flame starter as a cold starting deviceYeah you will most certainly will have them ,might be worth getting them tested to make sure the relay is powering them up?
Mind the old york diesels with the glow coil and easy start mod by Ford under the bonnet terry?
Think it was an element glow /flame throwerOur version of a flame starter was something burning in the air intake![]()
Themmauld times ehYou must be posh Gordon, we set fire to an oily rag and held it in the air intake
Most pre and post heat, on pre start for less than a second, post start can be on for up to 10 seconds, dependant on temp.Sounds ok it may stay on longer depending on outside temp .in the summer it may not even illuminate ,the beauty of high pressure diesel injection
Will also depend if the engine in direct or no direct injectionMost pre and post heat, on pre start for less than a second, post start can be on for up to 10 seconds, dependant on temp.
If it only stayed on for 30 seconds Paul, I wouldn’t worry too much about it. But certainly keep an eye on it.Preparing to leave Hereford this morning, followed the procedure and turned ignition on until lights gone out. Started first turn. Left running to demist windows.
About 20mins after turning engine off I restarted ready to leave and got the check glow plugs message and the orange glow plug warning light stayed on for about 30secs.
Will try to book it in tomorrow.
Paul.
IIRC, the 'Out & About' Thread referred to a Relay and/or sensor failure, which perhaps makes more sense than a glow plug, especially after you have driven the vehicle a decent distance from storage, to get the engine warmed thoroughly and a chance to get the equivalent of the 'Italian Decoke' done[?]. Even if it was a cold'ish day, after running the engine for 20 minutes, there should be enough residual warmth to avoid the 'Check glow plugs' warning message. If it were me, I would get it checked and repaired, if only to avoid a problem at a less convenient time for a recurrence in the future.Preparing to leave Hereford this morning, followed the procedure and turned ignition on until lights gone out. Started first turn. Left running to demist windows.
Moho is 2013 and 50K. Should I be disappointed if it needs new glowplugs ?
Paul.
It’s not unknown for glow plugs to be replaced at 60KPreparing to leave Hereford this morning, followed the procedure and turned ignition on until lights gone out. Started first turn. Left running to demist windows.
Paul.
Grief.......how much are the Glow Plugs ??? Didn't realise they were that expensive.The good news : Got the motorhome back today. All 4 glow plugs replaced, no dramas. no more warning messages.
The bad news : £564.
