Thule Load Carrier Plate not really adaptable without chopping it up a bit, so in case I want to go back to a standard carrier I decided to leave that alone and use another number plate mount I had spare.View attachment 65874
Still need to fit the number plate mount. In the standard place the door fouls on it so need to adapt that a little bit but should be easy enough to do.
Worked well (and this plate is actually more secure than the Thule one as well - I have lost one plate in the past that was clipped to the Thule mount).
FiammaRearBox-Finished by David, on Flickr
Still need to decide whether or not to do anything with the cameras.....
But using the rack means I should probably move the Garmin reversing camera as that is on the number plate which will be totally obsured of course. Still have the original Autotrail high-mounted camera connected to the drop-down TV as a backup () so depends how much use the box I suppose.
