Oil level checked, water levels too, tyre pressures all checked.
Filled with water, and flushed system through, heating fine, so is hot water on gas or electric, fridge fine too, and spare fridge now in garage.
Feet getting itchy!!
When did you last wash them. Terry? :rolleyes: Some Athlete's Foot Cream and clean socks every day should clear up the problem witin the week :D
You want a wee sniff Steve, to offer you a clue of my last visit to the mosque? :ROFLMAO: 🐾
Checked my san Miguel is cold here at chateaudun in the Loire
just back from a pleasant stroll around the chat and grounds
quite mild
We pushed on to Meung sur Loire [about 30 miles SE of Chateaudun] last Summer and to La Ferté-St-Aubin last March [when the Orleans roadworks made it sensible to get south of the City to avoid the morning rush hour]
Whats afoot in metric? You can join the club if you wish :whistle:
304.8mm, Terry, but it doesn't have the same ring to it ... :rolleyes: I don't have a club foot, just one leg 22mm shorter than the other after the 2nd hip replacement ... I find the list useful for shopping, though (y), more of a penchant than a leaning, really :D And please don't ask me on which side I dress, 'cos that'll just me a happy cross dresser [but only at weekends] ...
Steve [aka Stephanie, but only at weekends] ...
Today I fitted a voltage buck in a small case and wired up between the cigy socket and tv, problem ws the tv lost sound below 12.4v or so, now with this bit of home made kit it stays at 14.33v to the tv even if the battery falls to 12.2 or below.
I have also tested with the engine running at 14.5v, unit still sits at 14.33, so now when away the wife wont mis emerdale, god forbid.voltage buck.png
I have also tested with the engine running at 14.5v, unit still sits at 14.33, so now when away the wife wont mis emerdale, god forbid.View attachment 66106
Trev, your good lady only watches telly so she don't have to ;listen to you. 😁
went into Motorhome today ... nearly the middle of March. less than 3 weeks to British SUMMER time. broke off an icicle on the kitchen taps.
lets hope no pipe/tap damage has happened :( put heating pad next to water pump and turned on space heater and water heater to thaw pipes out
I keep a small blow heater on a timer of on plug in cold weather, I can the see the van temp from a sender unit in the house.
I thought I should check it was drained down as I left Liz to do it while she was down there when we got home, NO, good job I checked.
