rugbyken
Glad you understand these things, David. I would just have plugged the kettle in and rejoiced in not having to switch the gas on ... 'Steep Learning Curve looming' appears on the horizon ...It might be that the inverter has a built in Transfer Switch? i.e. If there is AC in, the Inverter AC out comes from the mains rather than the Battery power? that would be a neat feature,
Aha, just cricking my neck trying to read the writing on the side and it says "with transfer switch"![]()
hi . we have just bought the same one what battery's are you using my old 3/110ah leisure battery's only work the microwave for 3 minutes . Cheyannegot anew 2000w Renology inverter research says their second best after victron almost twice the physical bulk of my cheap chinese one which was rated as 4000/8000w , this unit comes with an AC input kettle type lead ? can’t see the reason for that unless it is to act as a battery charger?..??View attachment 64456View attachment 64457
These inverters have a mains auto changeover feature so that all your sockets connected to the inverter can be powered by the main hook-up if you are on a campsite, then when the hook-up is not available it goes back to battery power for the source. This should be a no-break change like a UPS system for a computer. It is a fantastic addition and I'm fitting a 1000W one in my new Ducato van conversion series on youtube.got anew 2000w Renology inverter research says their second best after victron almost twice the physical bulk of my cheap chinese one which was rated as 4000/8000w , this unit comes with an AC input kettle type lead ? can’t see the reason for that unless it is to act as a battery charger?..??View attachment 64456View attachment 64457
hi. i am not going to bother fitting it into the the motorhomes electric system as it has 2 battery's & a 100w solar panel alternating between the engine batt & the hab batt . the inverter & battery's will be a separate system stored in the half garage at the back from 2 / 120w panels with a couple of sockets in the m/hHi Ken, I fitted the same inverter in my van. If you want to use the auto switch over function, the hook-up wire goes direct to the kettle type plug, then put a lead from one of the 240 type sockets on the Inverter to the consumer unit, in my case, where the hook-up wire originally went.
If your at Hollingsworth Lake I'll show you my set-up.
Hope this helps.
Reg
I would suggest that is not the best way to configure this?Hi Ken, I fitted the same inverter in my van. If you want to use the auto switch over function, the hook-up wire goes direct to the kettle type plug, then put a lead from one of the 240 type sockets on the Inverter to the consumer unit, in my case, where the hook-up wire originally went.
Hope this helps.
Reg
hi wildebus . i have not explained myself properly its hard trying to write what's in your head. no the vans battery charger runs the 2 batts in the van only not the ones in the garage they will be charged from the 2 back panels that is where the inverter is which is for outside cooking .I would suggest that is not the best way to configure this?
If you install as you suggest, you have the Battery Charger running off the inverter when there is no hookup, which will do nothing other than waste power.
You could say " I only turn the charger on when I have hookup" which is one way to avoid the problem. However .... with the Auto switchover, you could lose EHU without realising and you inadvertantly have that charger on powered by batteries
The other problem you can get with the same scenario is running the Electric Room heater and the Electric Water Boiler off the Inverter as well.
Rather then between the EHU inlet and Consumer Unit, I would have the Inverter coming off one of the Circuits from the CU so you can avoid any risk of the devices you want to only ever work on Hookup (Battery Charger and Electric Room Heater) being fed by the Inverter.
That is what I do when on hook up, disconnect when not on hookup.You could say " I only turn the charger on when I have hookup"
not sure what the question was? was it on the other thread?hi wildebus . i have not explained myself properly its hard trying to write what's in your head. no the vans battery charger runs the 2 batts in the van only not the ones in the garage they will be charged from the 2 back panels that is where the inverter is which is for outside cooking .
i had my old system that way but the old inverter & battery's wasn't up to the job that's why i am upgrading . the inverter under powered the old leisure battery's died hope this explains things sorry to be a pain .Cheyanne
but like I said (and the bit you didn't quote from my reply) ... what about when the EHU external breaker trips for some reason? you will not know and be charging the batteries FROM the batteries.That is what I do when on hook up, disconnect when not on hookup.
Reg
hi wildebus . i am sorry i find it hard to explain my system . all i am doing is changing my inverter & changing my battery's in the back of the m/h which is completely separate from the m/h itself . i have never touched the m/h electrics as its to complicated with the sergeants command system . i have just added a system superette for outdoor cooking when on site as we winter in Spain & using the sites electric is expensive . Cheyannebut like I said (and the bit you didn't quote from my reply) ... what about when the EHU external breaker trips for some reason? you will not know and be charging the batteries FROM the batteries.
Obviously you can set up your van however you like, but I really don't recommend it as one for anyone to replicate, sorry.
David, I originally was talking to rugbyken when he queried the kettle type socket and supplied lead and why it is there, and offered to him to see my setup.but like I said (and the bit you didn't quote from my reply) ... what about when the EHU external breaker trips for some reason? you will not know and be charging the batteries FROM the batteries.
hi. sorry to be a pest but what kind of battery's will you be using & what charger please. as i have just bought the same coupled with these . Cheyanne https://www.ebay.co.uk/itm/115670729854?hash=item1aee83447e:g:~RwAAOSwtTZgrLDOgot anew 2000w Renology inverter research says their second best after victron almost twice the physical bulk of my cheap chinese one which was rated as 4000/8000w , this unit comes with an AC input kettle type lead ? can’t see the reason for that unless it is to act as a battery charger?..??View attachment 64456View attachment 64457
I can tell you some of the above, assuming it hasn't changed from last September ....hi. sorry to be a pest but what kind of battery's will you be using & what charger please. as i have just bought the same coupled with these . Cheyanne https://www.ebay.co.uk/itm/115670729854?hash=item1aee83447e:g:~RwAAOSwtTZgrLDO
You dont use an inverter to run a charger, solar panels do that directly through a good regulator, no need for an inverter.hi wildebus . i am sorry i find it hard to explain my system . all i am doing is changing my inverter & changing my battery's in the back of the m/h which is completely separate from the m/h itself . i have never touched the m/h electrics as its to complicated with the sergeants command system . i have just added a system superette for outdoor cooking when on site as we winter in Spain & using the sites electric is expensive . Cheyanne
