maingate
If I knew I would not be using the van for a while I used to inflate the tyres another 5 - 10 psi.Seriously you should, at least drive it up and down the yard wherever it is stored at least once a month to rotate the tyres and get oil around the top of the engine. Tyres start splitting where they bulge at the bottom and even wheel bearings don't like having the weight on them in one position for a long time. Hence the reason why you sometimes see wind turbines rotating very slowly, it's not because there is a slow wind, they are electrically driven round to save the bearing surfaces getting pitted.
