Bracknell MoHo
I also did the same last year. I had to replace bathroom sink tap and took the opportunity to remove (actually bypass) all the micro switches. for a reason that is not entirely fathomable to me it has resulted in a smoother water flow overall. I do think there are some pros and cons though to running a pressurised system vs micro switched.I did the very same and never had any problems since .
Removed all the micro switches as they are now not used .
Turn on the water and the pump starts a much easier and very simple answer
