Sharon the Cat
Popped into The Range in Shrewsbury on the way home and bought Kitty the new van £80 worth of mats, bungees, pillows, hooks etc. etc.
She has recovered the duel seat ,and as I type this she is upstairs recovering the other one .think that leaves two head restraints to do ,she got new foam which was bloody dear it's some special type( I'm told )Is that Fiona job then?
Are they self fitting covers then.New seat covers arrived. Open van threw em in and shot off wi g kids in car
If only if only EricAre they self fitting covers then.![]()
Are you no getting mixed up wi yer duke o argyles Steve? ( lumps/sealing Ring etc@Jeff Ex-Windsurfer reported the 'Cassette Full' light illumination after emptying, and we've had the same problem about 3 times this trip, albeit the light extinguished if the cassette was withdrawn and reinserted forcefully. Today was the exception and the light remained in the 'on' position, despite many attempts
I had followed the technical instructions only to use olive oil on the cassette seal (but haven't done so recently, relying on the new water to keep the seal and the arm moving freely. Some of the olive oil residue had formed a small gritty lump in a couple of places around the seal and the bumps were pushing the seal upwards, causing the 'full' light to illuminated. Gentle probing with a flat bladed screwdriver removed the gunge piles and the cassette is registering freshly emptied again. The rubber seal has seen better days, so it may be time to get a 'Refresh' kit, or even a 2nd cassette for those overnight stays at 'No Facilities' Aires. Only problem is finding space to store it; and then driving round with 17 litres of liquid human waste and pee until I can get to a Service Point. After my problem finding places to pee in Zaragoza, I'd quite like a break from these sorts of difficulties!![]()
If my ring was sealed, Gordon, the cassette wouldn't need emptied so often ...Are you no getting mixed up wi yer duke o argyles Steve? ( lumps/sealing Ring etc![]()
Where are you of to GordonShe has recovered the duel seat ,and as I type this she is upstairs recovering the other one .think that leaves two head restraints to do ,she got new foam which was bloody dear it's some special type( I'm told )I feel she is dragging her heals a bit ,thought it would be finished by now ,Hope she don't read this
Be flipping new flooring no doubt next as we're having the colour change
Think I will leave the front covers of till we're heading to newhaven next month
24th of June out for 88 daysBooked for France /spain? New.dieppe think 15 or 17 coming dave
Maybe a small rim leak over a few days, hard to detect.ThinkI have a slow puncture in one tyre (dropped from 67 to 48PSI twice now) so took to local tyre place ... couldn't identify any leaks?
Might be the TPMS Sensor causing very slow leak maybe? They replaced the valve core and will see if that has made a difference, but I might swap two sensors over and see if the pressure drop stays with sensor (sensor issue) or is on 'opposite' tyre (tyre issue).
I believe rim leaks are quite common in the older male, as is the loss of pressure, though the tablets helpMaybe a small rim leak over a few days, hard to detect.
dunno, but these were brand new top brand tyres (Michelin Cross-Climates) on brand new alloy wheels, so wouldn't expect leaks due to anything wheel-related (gone pourous, flaky bits on rim, etc)Maybe a small rim leak over a few days, hard to detect.
Yer erse would have been behaving like a camera shutter!Cut out and fitted some windows. Never done it before a bit nervous but took my time on them messured half a dozen times before cutting I found a jigsaw was the best way. Happy wae the results.View attachment 72562View attachment 72560View attachment 72561
