gasgas
Rolling road . . . . or drive down an Alp pass alternately brake / scream down in first gear / brake / scream down in first gear (because your brakes have overheated and faded) and arrive at a T junction at the bottom. You can't stop because the brakes have overheated. You swing the van round to the right and luckily there was nothing on the road at the time.Its the rear w cylinders that seeze up with sitting long times, shoes do also as you say require a bit of a burn in, rolling road is the only true way to test brakes.
At least, that is how I once tested the brakes. I vowed when I got home to renew them all .
