Wheels
47643
Hi, I have a x290 comfortmatic with 15" wheels. i am thinking about changing them to 16" still the same pcd of 118mm.Has anyone done this and are there any negatives.The tyres are due for replacement anyway
I changed for 15in wheel to 16in several years ago only prob I found it knocks your speedo out but I just us the satnav speedo so no prob I was using 225 x 70 x 15in tyres I now use 225 x 75 x 16in with a load rating of 120/121 so much higher than standard.
If you used a matching profile for the wheel+tyre combo, the speedo would not have been affected.
Here is one of many calculators on-line to find the right size - https://tiresize.com/tyre-size-calculator/
If you get bigger tyres, you would usually get tyres with a lower profile in order to keep the same rolling circumference. Pros and Cons -
Appearance to some is better;
less roll around corners - irrelevant really on a camper.
less give if you hit a pothole - also means more potential to damage a rim on a big hole.
FWIW, When I got new wheels, I decided to get new 15" ones to give a bit more suspension and the roads round here are crap.
the person who maintains the van reckons the speedo might be able to be recalibrated.I will have to give this some thought.
thanks for the replies
Nah. Get the right wheel and tyre combo and it will read the same. If you get a bigger rolling circumference, it will read a bit higher. if you go too far you will be fouling the tyres on the van bodywork.
Note that changing the rolling circumference will have other effects than just the speedo. Go larger and it will effectively change the gearing and you will be going faster then before at a given engine speed; your acceleration will be impacted and you could potentially increase the strain on the gearbox.
Reactions: GMJ
as part of upgrading the weight on mine i got the bigger wheels my speedo was always 7% out the bigger wheels corrected that fractionally better mph & on the whole a better driving experience but that may be more likely down to the air bags
I found the same Ken .same speed less revs + for me the alloy wheel I fitted had a different offset giving me a 3in wider track and the tyre are know where near the bodywork or suspention .
Hi, all changed the wheels and tyres. went for nexen roadian ct8, as they were original tyre and no issues with them.
The-wheel-shop. com, Rochester, provided the once used rims and delivered 24 hours later.The speedo is accurate at 30, 40 and 50 mph, still have to check 60 & 70
-397166562_20250221_161744_3311361_resized.jpg-398090083_20250221_161753_2755250_resized.jpg
If you fit full size tyres watch they dont hit the inner gaurds on full lock, my car does this.
The same van comes with 15" and 16" wheels so it shouldn't be a problem, my Speedo with 15" wheels is so far out that I look at the kph and divide it by two, so when it says 50mph it is actually 40mph,
Since I've fitted these new tyres tezz my speed is spot on at 30 mph and two mph slow at 70 so not much to worry about really .
If you fit a dash sat speedo you can change from MPH to KILOMETERS if crossing the chanel or ireland.
Right hand side middle dash, handy tool, cost about 6/8 bucks.van front.png
Right hand side middle dash, handy tool, cost about 6/8 bucks.View attachment 75494
your dash would drive me bonkers with all those leads snaking around 🐍🐍🐍🐍🐍🐍
Handy to fix if anything goes wrong, one is for inside/outside temp, one for speedo, other for dash cam and new one this week for charging my phone running magic earth when dash clamp fixed beside s wheel right side.
There are other round the van for kids phones and in bed departments. ;)
See a set above tv and red usb ph cable for my daughter, if that failed it would be the end of the world.:eek:van beds.jpg
Why on earth does one want to change to larger wheels?
Is there a performance advantage or is it just a vanity thing?
BIG WHEELS BIG TYRES LOVE THEM BETTER RIDE WHAT POT HOLES 😂DOES AFFECT SPEEDO A LITTLE MORE PRESURE ON G/BOX /ENGINE NICE ON MOTERWAYS SAT NAV OK FOR SPEED BETTER ON THE MUD LITTLE WORSE ON FUEL BUT I LOOK GOOD THANKS LADS GOT TO GO WITH WHAT YOU LIKE. OTHERS HAVE THERE OPINION GOING TO MAP MINE GET FUEL UP A LITTLE RENAULT MASTER LWB WHEEL SIZE 265/70/17 COOPER ST MAXX
