That was my thinking, I hate just throwing things away that may help someone else, it'll never be a ECU again.
Yup. I have a brand-new 40A B2B in the cupboard that I think has a simple fault that could be easily repaired IF you had the wiring diagram. But I don't and have no way to get one, so it will stay SNAFUed for the forseable future.
Got another 40A B2B (different make) that failed due to solar overload but is irreparable due to being 'potted'. People think having potted electronics is a great idea - but it costs extra money to do that AND it makes them uneconomic to repair.
I had two Sterling B2Bs repaired by Sterling. One was fine. They said it was a dry joint from original manufacture. That one still works as far as I know. They fixed it for free.
The other one had something more wrong with it (I don't know what) and Sterling replaced a pure with a hard link, because that was what new ones had. I was charged for this repair.
The fixed unit worked for a few weeks then it lost the magic smoke.
The circuitry was frazzled around where the fuse used to be.
I don't use Sterling products now,, but the point of this ramble is that sometimes a repair is throwing more money into a sunk cost.
I've repaired a few Inc chargers which are similar in a lot of ways circuitry wise.
In older units the thermal paste between the FETs and the heatsink dries up and goes crusty and the FETs overheat. Often there's a hairline crack in a solder joint in the terminal header block due to flexing under strain. If it's not FETs or a dry joint then it's often the PWM chip. Easy to identify and swap out providing the manufacturer hasn't kindly ground the type number off the top, typically only a couple of quid. Surface mount chips get fiddly to work on as I'm getting older, I received some SMT capacitors from digi key a while back that are so small if you drop one on the bench then it's lost because you can't really distinguish it from a speck of flipping dust ! Give me a valve amp with huge 2Watt resistors on turret strip any day.
I was fixing an iPhone last week. Just changing the charging port, nothing technical. But it struck me that the screws were small enough to inhale! These things are so tiny that my elderly fumble fingers struggle to control the tweezers.
Mine is a Nordellectro unit, and it stopped charging the LB when driving, so I was quoted £650 to fix it, like that's going to happen so I bought a dual controller, and paid to have it fitted, and then they fucked that up, Merlin saw and fixed the issue fairly easily, well he said some words and moaned a lot then it worked, do you know what I'm saying :D :D He's not as daft as he looks (not possible), so it all seems to be working now. I just need to go to the van and check out a few things tomorrow, so I know it is all sorted for the trip to France next week, sometime.
on the faulty B2B with a likely simple fault, I asked a friend who owns a company making, amongst other things B2Bs, for a suggestion what to do with this B2B (not one of his, I hasten to add).
His suggestion was succinct and to the point ... chuck it in the bin :)
A VSR with normally closed contacts doesn't make any sense at all Kev.
I think you've been put on a bum steer with this normally open or normally closed malarkey.
The difference between those two you linked to is the voltage, one is 12v and the other is 24v. Both won't close until a certain voltage level is reached, that's the job of a VSR, ie, the contacts are normally open at rest.
I was only looking at Durite, (to swap like for like) and I couldn't find a 12v version that was normally open, and as we now know, the one fitted to the van is the normally closed version, which should be here this afto.
The only advantage of a VSR is that it doesn't need a wire to the ignition wire circuit. I'd just fit a simple relay. Better, more reliable and less than a tenth the price.
A bit of an update.
I got a second BM6 for the leisure battery, not stricktly neccesary but useful to see how it is doing as it was knackered when I got the van 4 yeaers ago, so keeping an eye on it.
Ig nore the temp on the Starter battery as the unit is on the dash, it's there so I can get a BT signal from it but seeing as the Leisure battery is managing I may put it onto the battery.
The last five days.
I bought the battery about a year ago from Alpha.
019 Jenox Gold Premium Car Battery on 7 February 2024
Flat as a fart even though it's been hooked up to a NEW Ctek charger.
Smack my wrists if I am wrong but isn’t the Ctek charger a trickle charger. If this is the case trickle chargers will not charge a flat battery to full charge. You would need to bench charge the battery using a full battery charger.
The bulk and absorption stages are used to speed up the charge process and aren't strictly necessary, float charging will get you from flat to full charge eventually but it'll take a lot longer.
FFS, I'm off down to see our Merlin next week, so I wandered down to the van to see if it was all ship shape, as it's not moved since early June, so I looked round and a few things need to be put away, and I thought I'd check the VB voltage and fire it up, and maybe go and refill the LPG as it was empty.
Hmm, didn't want to start, VB volts dropped fast to just above 11v, I rings Merlin as he's me go to man for sparky stuff, I try again and it fires up, clouds of black smoke, coughs farts and dies, so I try againa few times, and it doesn't want to go, so i left it a bit and finally it gets going a bit better, so I locked the house up and moved the car and took it for a good run, 90 miles actually a good three hours ans it seems fine now, no idea what the actually problem was, it felt like it wasn't getting enough fuel, but Diesel doesn't evaporate like petrol might.
