I am thinking of changing the springs on my Ducato based motorhome and wondering if anyone here has done this and what difference they noticed?
To recap ....
The original owner of my Motorhome had the rear leaf springs replaced after one failed. I don't know if it was fitted with the single or the double lead spring (I think maybe single as that was quite common and is too weak for a 3.5t van?). I suspect one reason why it failed was he likely ran at the 3.5t weight limit a lot of the time or maybe beyond it.
He chose to get triple-leaf Jones Springs fitted. These are quality springs and the ones fitted are VHD - Very Heavy Duty - Springs. I think they are too powerful/strong/stiff for my motorhome as I have always found the ride at the rear very 'crashy' with very little give, and when you look at the rear, the third leaf is never in contact at the ends regardless of how much weight is at the rear. The back end never seems to drop any lower. I don't have any experience of a standard setup though so not got anything to compare with in terms of ride.
I fitted rear airbags and they never made any difference as the distance from axle to bump stop was just too large for the airbags to do anything without going beyond the maximum pressure, which is no use of course, so removed those airbags again.
So I think reverting to a double spring could be a good option, and probably a 'normal' double-spring rather than a Jones Spring (I get the impression even the Jones Double Spring is very stiff still?). And then maybe try adding Air Suspension again as those people who have that seem to love it!
So the question is ...
What difference has anyone noticed after changing spring types? the most likely change is from single to double springs I would guess? Did it make the van less bouncy? Improved the drive or hardened it a bit much? anyone else ever run triple leaf springs and how do they find them?
What I don't want to really do is do this work and spend the money only to find there was no point in changing, but I am getting a bit fed up with the crashiness at the back and lack of any rear suspension in effect.
To recap ....
