Exwindsurfer
I fitted twin springs and found them to harsh
Were they any better with your fire wood on the back?I fitted twin springs and found them to harsh
Yes a lot better lololWere they any better with your fire wood on the back?
Del
Motorhomes are not like vans. An empty van weighs much less than a loaded one. For them, two spring rates are good.The thing with the 1+1 as decribed to me by the technical guy at the company is that in normal use it is the same as a single leaf spring and only when the extra assistance is needed when a single leaf could be overwhelmed does the second spring comes into play, which sounds like a good way to go.
sorry, but wrong.AIRBAGS NEW SHOCKS LEAVE THE OLD SPRING JUST TO TIE THE AXLE.
That could certainly help in some circumstances.Bit late to reply, but here is what happened for me on an older Ducato. Ride was too soft and handling was not great. Left the springs and chocks as they were and fitted the airbags (Dunlop I think it was?)
Now with the ability to adjust the ride height and stiffness, the handling is great.
Very happy
yup, just remind me never to get lottery numbers from youi am never wrong as you can see![]()
There are indeed and extremely rubbish they are too....The dampers are as one might expect a key aspect of the suspension system. The originals required only 20 kg to compress them on a 4 year old van. I replaced these with Bilstein B6 camper advanced....I did the Bilstein training as part of the upgrade....to fit the rears I had to use a small jack to get them in place.presume there are rear shock absorbers at the back on a Ducato. Is th
Adding air assist to springs that are a bit weak is going to help a lot.Bit late to reply, but here is what happened for me on an older Ducato. Ride was too soft and handling was not great. Left the springs and chocks as they were and fitted the airbags (Dunlop I think it was?)
Very happy
