Exwindsurfer
I fitted twin springs and found them to harsh
Were they any better with your fire wood on the back?I fitted twin springs and found them to harsh
Yes a lot better lololWere they any better with your fire wood on the back?
Del
Motorhomes are not like vans. An empty van weighs much less than a loaded one. For them, two spring rates are good.The thing with the 1+1 as decribed to me by the technical guy at the company is that in normal use it is the same as a single leaf spring and only when the extra assistance is needed when a single leaf could be overwhelmed does the second spring comes into play, which sounds like a good way to go.
sorry, but wrong.AIRBAGS NEW SHOCKS LEAVE THE OLD SPRING JUST TO TIE THE AXLE.
That could certainly help in some circumstances.Bit late to reply, but here is what happened for me on an older Ducato. Ride was too soft and handling was not great. Left the springs and chocks as they were and fitted the airbags (Dunlop I think it was?)
Now with the ability to adjust the ride height and stiffness, the handling is great.
Very happy
yup, just remind me never to get lottery numbers from youi am never wrong as you can see![]()
There are indeed and extremely rubbish they are too....The dampers are as one might expect a key aspect of the suspension system. The originals required only 20 kg to compress them on a 4 year old van. I replaced these with Bilstein B6 camper advanced....I did the Bilstein training as part of the upgrade....to fit the rears I had to use a small jack to get them in place.presume there are rear shock absorbers at the back on a Ducato. Is th
Adding air assist to springs that are a bit weak is going to help a lot.Bit late to reply, but here is what happened for me on an older Ducato. Ride was too soft and handling was not great. Left the springs and chocks as they were and fitted the airbags (Dunlop I think it was?)
Very happy
Sorry for the late reply - I had two extra leafs inserted in the rear springs of my Ducato (Globecar 2011) some years ago as it was quite low on the back and would scrape on certain inclines, the waste tank is quite low under the centre of the van, I was worried by this. I also had a very steep drive where the towbar scraped as I came to the top and turned. The job was done by Midland Springs in Nottingham who told me at the time that the local council had all their Ducato's done with either one or two extra leafs prior to use. This has made a big difference to my van, the sit height is much better and it seems to have made the ride much better, maybe its a little two high as the sliding door now is slightly downhill, but I can live with this and it has never cauught or clipped anything like it did before.I am thinking of changing the springs on my Ducato based motorhome and wondering if anyone here has done this and what difference they noticed?
To recap ....
The original owner of my Motorhome had the rear leaf springs replaced after one failed. I don't know if it was fitted with the single or the double lead spring (I think maybe single as that was quite common and is too weak for a 3.5t van?). I suspect one reason why it failed was he likely ran at the 3.5t weight limit a lot of the time or maybe beyond it.
He chose to get triple-leaf Jones Springs fitted. These are quality springs and the ones fitted are VHD - Very Heavy Duty - Springs. I think they are too powerful/strong/stiff for my motorhome as I have always found the ride at the rear very 'crashy' with very little give, and when you look at the rear, the third leaf is never in contact at the ends regardless of how much weight is at the rear. The back end never seems to drop any lower. I don't have any experience of a standard setup though so not got anything to compare with in terms of ride.
I fitted rear airbags and they never made any difference as the distance from axle to bump stop was just too large for the airbags to do anything without going beyond the maximum pressure, which is no use of course, so removed those airbags again.
So I think reverting to a double spring could be a good option, and probably a 'normal' double-spring rather than a Jones Spring (I get the impression even the Jones Double Spring is very stiff still?). And then maybe try adding Air Suspension again as those people who have that seem to love it!
So the question is ...
What difference has anyone noticed after changing spring types? the most likely change is from single to double springs I would guess? Did it make the van less bouncy? Improved the drive or hardened it a bit much? anyone else ever run triple leaf springs and how do they find them?
What I don't want to really do is do this work and spend the money only to find there was no point in changing, but I am getting a bit fed up with the crashiness at the back and lack of any rear suspension in effect.
