Deleted member 11
Do you know the correct tyre pressures for your vehicle and how often do you check them - honestly?
What is the rear axle weight?I had the wrong tyres initially but after correcting that it still gives a warning that rear axle load exceeds the maximum permissible level.
Tyre size is 225/70 R 15 C with load rating 112/110R. Tyres are Conti Vanco 2 on the back and Vanco 100 and 2 on the front, the pressures I have been using are nearly right (3.67 front and 4,5 rear).
What gives with the warning?
I am a woman and I haven’t a bloody clue. It is written on a label somewhere[/QUOTE
That's quite woring if you don't have clue I hope you take it to some one that dose. When was your tyres last checked for weir & condition + pressure??? The tyres is the only contact that your van has with the black stuff and a flat tyre likes the green bits. I like to check pressure + visual of side wall before I set off and when I stop I will go around and put a hand on all 4 tyres + hubs to feel that they are over hot
Me too!Yes, and have monitors fitted, so constantly checked.
My van has Alloys fitted so I check once a month
Everyone has a tpms, it's your eyes & a pressure gauge.I read somewhere that all vehicles manufatcured after 2014 must have TPMS. How do you know if you have it and where to look?
