AndyWill64
Yes, it says that. The wiring inside the van is to the same standard as a hookup cable.
Indeed, but the general public outside the van can't touch what's inside.
Hi Bruce, I am moving into my Doblo micro camper full time in 4 weeks and I'm curious about the EV charging cable Juicy Brucie. I have an Ecoflow Delta 2 1800w power pack and wondered if I could attach a hookup cable to it (with built in RCD) to charge my ecoflow? I have seen some van builds that attach this cable to the plug in port on the outside of their van as an easy way to charge at camp sites. If the cable is not considered 'safe' enough is there a way around it?Thanks for the post Phil. If anyone has any questions, please post them and I will do my best to answer them.
WOW! good luck with that, I'd be looking for a lot bigger van than that in less than 4 weeks.Hi Bruce, I am moving into my Doblo micro camper full time in 4 weeks and I'm curious about the EV charging cable Juicy Brucie. I have an Ecoflow Delta 2 1800w power pack and wondered if I could attach a hookup cable to it (with built in RCD) to charge my ecoflow? I have seen some van builds that attach this cable to the plug in port on the outside of their van as an easy way to charge at camp sites. If the cable is not considered 'safe' enough is there a way around it?
Air bnbs and regular campsite are going to be out of my budget but I might be able to blag a cable as a Xmas present if its viable.
Thx in advance
Deborah
Hi Deborah,Hi Bruce, I am moving into my Doblo micro camper full time in 4 weeks and I'm curious about the EV charging cable Juicy Brucie. I have an Ecoflow Delta 2 1800w power pack and wondered if I could attach a hookup cable to it (with built in RCD) to charge my ecoflow? I have seen some van builds that attach this cable to the plug in port on the outside of their van as an easy way to charge at camp sites. If the cable is not considered 'safe' enough is there a way around it?
Thx in advance
Deborah
I've had it 2 years and spent months away in it at a time, both summer and winter, and it fits me fine. Both size wise and financially.WOW! good luck with that, I'd be looking for a lot bigger van than that in less than 4 weeks.
A motorhome with a pretty big battery bank is maybe 5kWh - so the charge cost is maximum £6 in your worst case scenario.Leaving aside the issues arou;t taking up charging spacesv using an EV charger for hookup power is a pretty expensive approach. Generally they run at 69p to 120p per KWh, on top of the cost of the cable. It'd be cheaper to go to a cheap campsite to charge.
I was under the (possibly wrong) impression that the cable was over £100.A motorhome with a pretty big battery bank is maybe 5kWh - so the charge cost is maximum £6 in your worst case scenario.
cost of cable would be covered in maybe 5 visits typically, or 10 visits at a cheap site with EHU.
I don't think I've ever paid as much as £25 for a campsite, but then again I hardly ever want hookup.Cheapest campsite with EHU is ~£25 in.
The cable is an expensive outlay but could pay for itself in the 1st year.
Neil. I know how you travel, and that in isolated places you use your generator to top up batteries etc.As I do things now they aren’t much use to me, certainly not enough to add another cable to what I already carry. I only really go into towns to shop and when the shops are open the points could be in use. I haven’t come across any chargers on byways and such so far but who knows in the future.
If I thought I was going to be in places where I would use it then Yes, I would buy one of the cables. A couple of years ago I would probably have bought one anyway but since emptying out all the stuff I don't use I try not to add more lolNeil. I know how you travel, and that in isolated places you use your generator to top up batteries etc.
BUT
If you were starting out, would you still go for the generator, or consider one of Bruce’s leads.
I ask this because, this winter trip I been on has showed me, just how much I depend on solar. Short dark days, have depleted my battery and lpg much faster than I expected.
One of Bruce’s leads, may have helped. Okay, not necessarily on the NC500.
This is my first extended winter trip in the UK. It’s not quite worked out as I would have hoped. But I will try again..Del, what size mains charger have you got?
Obviously this EV point lead could be used with any charger, but (IMO anyway) to make it really work overall you need to have Lithium Batteries (you are covered there) and a pretty decent sized mains charger.
Lead charges too slow for this I reckon, especially when it is in the last 20% of the charge. And if you are using an EV charge point you really want to be in and out as fast as you can to avoid/minimize possible conversations with those people who think they are the only ones allowed to even look at an EV charger.
My batteries went pretty low whilst the Motorhome was away at the garage for 5 days. I got them to plug it in a couple of days ago (needed to make sure the freezer stayed working!) and it took over 7 hours to get the batteries replenished after having taken 440Ah out of them. I wouldn't really want to be sitting at an EV point for anywhere near that long. If I got one of Brucies cables I would also get another charger to work alongside the 70A one in the Multiplus to get the charging done faster.
My Fridge/Freezer takes around 50Ah/day. That will be the single biggest use of electric that you cannot change if you switch to a Compressor Fridge. Mine is a 240V model via an Inverter but a 12V one will be more of less identical.This is my first extended winter trip in the UK. It’s not quite worked out as I would have hoped. But I will try again..
Battery? I’m pretty well sorted here. Ditched everything and replaced it all with a Fogstar 460ah. Charge, Hook up, 50ah Fogstar, B2B 50ah Orion XS, as well as 700ah of, useless in December, solar .
I’ve found that in order to keep the battery charged sufficiently, running the engine, driving/static running, periods were lengthy. I’ve been using electric for cooking for over a year, and tbh, I’ve got used to it. So easy to bung stuff into the microwave or Airfryer. Easy cooking.
Without constant solar input, I’m having to revert to gas. Although the way I cook, using gas or electric makes little difference. Some people would call it, simply bodyfiller.
I had considered changing the fridge to 12v as well. Not so sure about that now. More depending on electricity?
If, and hopefully when, I do another winter trip. I will probably bring one of Bruce’s leads with me. But as I’ve said in an earlier post, on the NC500, charging points are as rare as hens teeth.
NB. At this point, I think it’s best that I say, it’s been my decision to go this route, I take full responsibility for the situation I find myself in. I’ll do what I think best to solve this dilemma.
As much as 50ah? Didn’t realise it would be that muchMy Fridge/Freezer takes around 50Ah/day. That will be the single biggest use of electric that you cannot change if you switch to a Compressor Fridge. Mine is a 240V model via an Inverter but a 12V one will be more of less identical.
To fit a 12 volt compressor fridge ?In UK when there is no solar Del you only really have a limited number of choices when you use a lot of juice like you I think. I would say Juicy Brucie, Hook up or generator. I did Scotland this last winter and managed with short trips and my B2B which is only a 30A one. That said I wasn't cooking with electric or heating with it. Was first Winter I had not needed to use my genny but it was also the first winter where I kept moving lol
