jagmanx
Yes !I must keep up . Thanks
So a flat panel works ok in summer. Tick /
Here is a bit of info folks on this thread might find interesting?
So the graphs below show the sunlight level at the English-Scottish Eastern Border in the last year, showing irradiation and UV Levels.
This should tell you what you could expect to harvest on your solar panels when angled and facing south (like the little panel on my weather station is). This is bearing in mind that the Wattage quoted for a panel assumes a irradiation level of 1000watts/m2 received (so less than that, less power; more, more power. Ignoring heat effects on PV Panels)
This is for the week following the longest day in 2020
And similarly, the week following the shortest day in 2019
A rather big difference!
The combination of a greatly reduced level of Solar Radiation, combined with a significantly shortened Solar Day means PV Harvesting in winter is dramatically curtailed*
*waste of time?
Good GuessThanks David, that's very useful information.
I guess the data is from about latitude 55.6° ? And the panel is facing south at a fixed angle of about 35° to the horizontal?
Colin![]()
NO lololCan I mention the G word?![]()
Notice how I asked first though lolNO lolol
David i think it would be much easier to tilt the panels lololVery interesting thread. Thanks for posting Colin.
Out of interest when angling the solar panel could you use mirror deflection on to the solar panel to enhance performance? Has anyone tried this?
Cheers. David.
